Running drama again
Re: Running drama again
Postby andymac on Thu Jul 04, 2013 12:11 am
I might have a couple of feet of starter cable, already terminated. I'll have a look tomorrow.
Failing that, you can get new here http://www.vehicle-wiring-products.eu/V ... ycable.php
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
Postby Mattious on Thu Jul 04, 2013 12:47 pm
Thanks mate,
Got the chip today, so replaced the 195 chip with the new Ahmed bajoo one and she's running a treat, taking nothing as concrete I shall attempt test 2 later! As of yet there's no hesitation in any gears on boost :D
Car idols slightly high always seems to since my ownership so looking at previous threads maybe it could be TPS ?? I see the gaskets aren't easy to obtain? So I was thinking, maybe I could re use the gasket with a small outline of locktite gasket sealant ... Or is that an an epic fail in the making ?.
Mattious
Your car: Fiesta rs turbo
Postby jayrs on Thu Jul 04, 2013 2:59 pm
Dude men don't need instructions! Lol
Auto sparky is the way to go, if you get the wrong wire even thick stuff it can melt it.
I agree with not driving it much without the chip, although if taken easy it will prob be ok sometimes better safe than sorry comes into play.
Postby Mattious on Thu Jul 04, 2013 3:55 pm
Hahahaha,
Well test 2 has been conducted and passed with no problems, (short boosts:- happy to say there was no holding back/spluttering)
Later on I shall conduct a long road test if this play ball, then I think 'gets excited' this new chip has worked!.
Mattious
Postby jayrs on Thu Jul 04, 2013 8:30 pm
Postby Mattious on Thu Jul 04, 2013 9:03 pm
Jay. And others that have had any input at all (stevo for parts) thanks for helping / guiding me its looking good at the moment , going all good :D smiles today.
Next up , get it set up !.
Mattious
Postby jayrs on Thu Jul 04, 2013 11:04 pm
No worries fella :)
Postby mikeymikeyp on Fri Jul 05, 2013 11:50 am
Get it set up as soon as you can it might be okay but best not kill an engine for a poxy 80 odd quid
mikeymikeyp
Postby Mattious on Sat Jul 06, 2013 2:45 pm
Yeh very true , she can stay Parked up for now , get her set up at the end of July. Far to hot at the moment to play out anyway haha!.
Long live this weather tho!!! .
Mattious
Postby andymac on Sat Jul 06, 2013 8:09 pm
jayrs :Auto sparky is the way to go, if you get the wrong wire even thick stuff it can melt it.
Which is why you normally have a thicker cable to the starter than the alt, a starter can draw a few hundred amps. :D
andymac
Elite Pie Master
Elite Pie Master
Postby Mattious on Sun Jul 07, 2013 9:11 pm
How many earths in total should come straight of the battery? I have four!,Is this right lads?.
Mattious
Postby jayrs on Mon Jul 08, 2013 8:20 am
Damn I can't fully remember lol but yeah I think 4 is right.
If I remember rightly you should have the
Main earth with square terminal, a black one that goes to battery tray, a small brown to inner wing, and a largish wire with a ring connector
Postby Mattious on Thu Jul 11, 2013 8:04 pm
Think it's correctly wired up from the battery , cheers jay,
Instaid of opening up more threads I may aswell as couple of questions on here,
1) what would benefit me more, a RR set up or a 'live road'? Set up?
2)Can a t3 conversion be done while the engine is still in?. And is it fairly easy to do?.
Mattious
Postby jayrs on Thu Jul 11, 2013 9:43 pm
Yes a t3 conversion can be done with the engine in, its a case of fit the turbo, plumb it up sort the exhaust, mess with the rad for clearance and done, it has its issues due to space but that's it really.
Unless you want to put a oil return in the sump then it means sump off but you can swap out the block fitting for a t3 one.
As for Set ups, ive never had a live map before so can comment on that side of it, but I think the general thing is that its better... But that's one to get answers by someone else tbh
Postby Mattious on Fri Jul 12, 2013 7:27 pm
Cheers jay, it's something I am contemplating for next summer.
Had a flat bat today , really need to get some cable and rewire that live !.
Is there anywhere that does replica headlight protectors ?? Love them but at the price the genuine ones fetch lol!
Mattious
Postby jayrs on Fri Jul 12, 2013 7:33 pm
Maybe but I don't know of anywhere fella, I'm sure if there was it would of been posted on here by now
Postby Mattious on Sun Jul 14, 2013 9:25 pm
Do you know what's driving me mad , I mean really potty?. My interior view mirror keeps falling of , what's best to keep them stuck on ? I've tried both thick and thin double sided tape, that's not worked!.
Mattious
Postby jayrs on Mon Jul 15, 2013 12:05 am
Scrape off all the sticky tape from the mirror and glass and clean it after with something like thinners then try it again with a decent sticky mirror pad, don't be tempted to super glue it lol
Postby stevo™ on Sat Jul 20, 2013 6:27 pm
glad it sorted it bud :D
t3 conversion is a peice of piss the only hard part is either getting a full t3 stainless exhaust or chopping the down pipe to suit
iv got
a full frst stainless with erst t3 stainless down pipe
t3 oil return rubber mint with the union the pushes into the block
a t3 manifold
all thats needed apart from the above is a erst top boost hose, a t3 turbo, a erst oil fed pipe (burton power sell them)
it took me about an hour to swap it all over and that was 6 years ago when i wernt really that clued up
stevo™
Postby Mattious on Tue Jul 23, 2013 10:45 pm
Cheers steve, PM me a good price for all the parts you've listed above mate :-) !.
Mattious
Postby stevo™ on Wed Jul 24, 2013 7:43 pm
ok bud il have a think
stevo™
Postby Mattious on Tue Jul 30, 2013 9:24 pm
Guys,
What amp cable should I be buying for the battery to starter motor is 110amp ok? Or should I go higher ?
Mattious
Postby Mattious on Thu Aug 01, 2013 8:44 pm
Evening all,
I've now replaced the bat to starter cable , and the starter to altnerator cable, today.
I only managed a 10min drive today , when I killed the ignition and left it 30 mins came back and it was dead!. Just wondering if that's because I haven't charged the battery up enough? Think it's done about 10 miles in the last 3 weeks .?.
Mattious
Postby andymac on Wed Aug 07, 2013 8:43 pm
jayrs :Scrape off all the sticky tape from the mirror and glass and clean it after with something like thinners then try it again with a decent sticky mirror pad, don't be tempted to super glue it lol
There's actually a specific glue for doing this iirc.
andymac
Elite Pie Master
Elite Pie Master
Postby snake on Wed Aug 07, 2013 9:18 pm
Get genunine ford sticky pad, they are about 70p or so!
snake
Trainee Burger Flipper
Your car: ford
Previous
