Running FRST with no thermostat
5 posts • Page 1 of 1
Right I'm sure this subject has been chatted about before but owing to the FRST's regular love of high temperatures does anyone run their car without a thermostat? I'm currently running an MSD 82 degree item & I know their designed to open up a little quicker but as my car wont be used all the time & warming up times not being an issue, is their any real benefit in running without 1? Does the water flow being less restricted become a benefit? Any advice greatly appreciated
CheeRS
BOBFRST
CheeRS
BOBFRST
- BOBFRST
- Your car: 1991 Fiesta RS Turbo
Re: Running FRST with no thermostat
I did this a good few years ago on my Rs. It's all well and good sat in traffic, but when flying down the motorway the engine temp never reached Normal operating temp.
Heater never got warm either
- knuckles
- Your car: Fiesta Rs turbo
higher fuel consumption too if the ecu thinks engine is still in warmup stage.
1.6 si
- Mav Singh
Mav Singh :higher fuel consumption too if the ecu thinks engine is still in warmup stage.
i was after lower temps in my si, insted of a lower temp thermostat i changed the fan switch to a different one. it runs for longer. standard si rad fan switch is 95c-90c diesel one was 95c to 88c. you can even get a 92-87c one if you want fan to kick in earlier which is the one i went for. no point in getting on that kicks in at 80c otherwise fan will be spinning when your on the motorway.
here is the 95-88 one: https://www.autodoc.co.uk/fae/2495657
here is the 92-87 one: https://www.autodoc.co.uk/hella/938617
they fit my si rad no probs. not sure if they are for the rs turbo, the same website list fan switches for the rs turbo that are 105-95c. thats hotter running.
1.6 si
- Mav Singh
Sorry guys only getting to reply to this now ffs I haven't been able to get on the site for some reason Thanks for all the replies. I think im compounding the normal FRST heat issues as im running a T3 which radiates heat like hell onto the back of the rad when stationary & im running a pro alloy front mount which restricts airflow to the rad even more, im running an MSD fan switch already so that's covered & a high flow Spal fan, but my plan of attack is to heat wrap the entire manifold & exhaust housing then put a turbo bag over that, wrap the remainder of the exhaust downpipe, fit a stage 2 Airtec radiator with an enlarged core & bigger frontal area & add a second fan on a manual switch. Hopefully that will do the business..........& if not £5 of petrol & a box of matches will soon sort it Though any further ideas will be greatly appreciated but don't say ceramic coating cos im already poor
CheeRS
BOBFRST
CheeRS
BOBFRST
- BOBFRST
