running probs
running probs
Postby fiestajim23 on Wed Apr 23, 2014 8:18 pm
Hi guys my frst seems to run fine for a while then it sort of drops off almost like there's no fuel getting thru sometimes cutting out will then go again for a bit with no probs no set theme happens when hot or cold in traffic or on a run it runs well when its ok took the amal valve off had new plugs, leads , coil pack had fuel pressure checked when this happens and it was ok any advice cheers jim
fiestajim23
Your car: Fiesta RS Turbo
Re: running probs
Postby georgiocat on Thu Apr 24, 2014 5:18 pm
I had a similar problem,if not the same from your description,when I did the RST transplant in my Escort. I had installed a wideband lamda and under no obvious reason, day or night, lights on or off, rad fan working or not, it suddenly started to lean from 14.7 at idle and going to 19 and even 22 AFR sometimes... for no apparent reason, it started to hunt and was ready to turn off. I checked the fuel pump, tested the fuel pump pressure, regulator, hoses, even ultracleaned the injectors. The solution found when I replaced the power wires (+12V) from the ignition relay to the ECU and also checked and renewed the grounds in the engine loom. I would suggest to check the condition of the ECU printed circuit, although not for the faint hearted since you need to dismantle the ECU and check for faulty solderings on the printed board. They tend to break after all these years and the traffic bump and rattling from the roads. You need to take care of what you touch since you can burn the ECU from electroistatic discharge which can be as high as 30000 volts or even more. If you don't have the needing knowledge, better skip this...
My Ford Escort ride
georgiocat
Re: running probs
Postby fiestajim23 on Thu Apr 24, 2014 8:13 pm
Thanks mate think that's a bit out of my league had crank sensor wiring replaced and it seemed ok for a while and now its started again fed up of it now :-?
fiestajim23
