Russ' mint green FRST , update :)
Re: Russ' mint green FRST--UPDATE
Postby russ-RST on Fri Oct 28, 2011 3:39 am
Well might be getting this back now as it was on my gf's drive but split up with her do gotta move it :rolleyes: if I can't put it anywhere going to stick it on the road again although will only be doing little bits till Xmas cos I'm only on a temp job contract don't want to spend it all loose my job and have no money again :lol: It should be sorting something out this weekend so might get some pictures of her as she desperately needs a wash :oooh:
russ-RST
Your car: fiesta rs turbo
Postby Rs Adz on Sun Oct 30, 2011 11:07 am
glade your still on with this
Rs Adz
Your car: xr2i and mk1 fiesta
Postby russ-RST on Sun Oct 30, 2011 2:01 pm
Oh yes :lol: I don't think I will ever sell it tbh :lol: :rolleyes:
russ-RST
Postby Rs Adz on Sun Oct 30, 2011 2:41 pm
good to hear it probably the most individual frst rep
Rs Adz
Postby russ-RST on Mon Oct 31, 2011 12:43 am
Thanks that's what I'm going for really everyone tends to stick with what's tried and tested I want to try and build my fez a little different, was thinking going mad with some mental wheels but 1. They are expensive 2. I can't make my mind up on what ones :lol: and 3 I'm skint ATM and what some wheels that will help with grip so no stretch rubbish so I'm thinking of getting some escOrt gti ones again and slap some proxie 4's or parade spec 2's on them??
Hoping to have my car nearer home some time soon and il chuck some pics up as ATM it's minging :aaah: hasn't been touched since USC , it still has my sleeping bag in the boot :lol:
russ-RST
Postby russ-RST on Thu Nov 24, 2011 5:52 pm
Well fitted the escort m/c and servo today everything went ok all the brake pipes went straight in with a little bending and had to bore out the holes on the mount abit to get it to bolt up, everything went fine bled up really well but then went to test them and the pedal is rock solid and I think the front left caliper is siezed on :( what can I do? Will driving it up and down the road free it up or will I break something ? Or shall I just take the wheel of and give it a bashing with the hammer and bleed them all again?
Russ
russ-RST
Postby rsturbonutter on Fri Nov 25, 2011 4:40 pm
nothing will break driving it up the road but i doubt it will free them up. you could try removing the pads and pumping the cylinder out and push it back in do this a couple of times it sometimes works (well it has for me).Also when the cylinder is pupmed out try puttin a bit of duck oil or something on the cylinder itself before pushing it back in just to lubricate a bit.
rsturbonutter
Your car: Fiesta RS turbo
Postby russ-RST on Fri Nov 25, 2011 8:55 pm
It's the servo I put some washers on the back to space it away ( seems the rod that goes to the brake bar is too long?? ) and it was ok for a bit then they came back on again :x more washers I suppose :rolleyes: has any1 else had this problem??
Need help meant to be taking a bird out tomorrow :rolleyes:
russ-RST
Re: Russ' mint green FRST, NEED HELP!!!
Postby Smo on Fri Nov 25, 2011 9:47 pm
Sorry if I've missed it Russ and you've already done it or bought it modified, but the Escort MC needs the rod shortening by 20mm or something, I can't remember exactly, but that's the figure that sticks in my head.
Smo
Postby russ-RST on Sat Nov 26, 2011 1:19 am
s**t :/ what master cylinder can I use ?? Is there no
Other way to fix it?
russ-RST
Postby russ-RST on Sat Nov 26, 2011 1:22 am
If I can space the servo away from the mounts 20 mm will that work? :-?
russ-RST
Postby jonyb4 on Sat Nov 26, 2011 2:56 am
sounds like its the escort master cylinder not the mondeo one, same size but the rod on the mk5 escort needs cutting and re welding together by 1cm, (shortening it basicly)
Postby russ-RST on Sat Nov 26, 2011 10:11 am
Yeah it is an escort one, didnt no that, what rod are you guys talking about here? If I knew what to do I'd give it a go anyone got a pic or diagram?
russ-RST
Postby DanFraser on Sat Nov 26, 2011 10:51 am
I would strongly recommend a mondeo master cylinder and servo instead. It has some drilling needing doing on the mounting bracket, but the rod positions correctly and it's stronger. The only thing you may have to do is washer the rod into the pedal like I did. An M reg mondeo with a blocked off clutch feed is perfect.
DanFraser
Your car: Ford Fiesta SI 1.6
Postby russ-RST on Sat Nov 26, 2011 6:45 pm
I will be getting a Mondeo servo soon will I have to use a Mondeo m/c aswell ?? At the moment iv spaced it out so the rod is at the right length there is loads of thread thru so it's safe it's only so I can move it around not driving it any where :rolleyes:
Gave it a quick wash today as it was filthy :aaah: will give it a detail soon but it's alot better than it was :lol:
russ-RST
Postby russ-RST on Sat Nov 26, 2011 6:46 pm
** big thanks to Simon (smo) for helping me out :Q nice one mate :)
russ-RST
Postby jonyb4 on Sat Nov 26, 2011 9:54 pm
dont bother getting the mondeo one if you already have a escort one, can you get access to a welder?
ill upload the pictures now
but basicly, the master cylinder rod on the back of the servo that sits betweent he two brackets, it has a knuckle on the end, this rod needs cutting in half and shortening by 1 cm, then rewelding back on
the brackets simply need some filing out its piss easy, i done it in a few mins
pics in a min
Postby jonyb4 on Sat Nov 26, 2011 10:06 pm
here we go
escort mk5 servo
the servo rod that needs shortening, needs 1CM cutting off for use on a mk3 fiesta
the bracket just needs minor filing out, simply offer the brackets up to the mounting bolts on the bulkhead to see how much needs filing away
no point drilling it it took me less than 5 mins
fitted (two of my outputs were blocked off as i have ABS)
Postby russ-RST on Sun Nov 27, 2011 3:14 am
I know all that Johny but I don't have access to a welder that was my problem, hence why I spaced it out instead but thanks anyway
russ-RST
Postby russ-RST on Sun Nov 27, 2011 10:30 pm
Right got another problem with the car, it runs on 3 cylinders when it wants too then whilst driving it it gets power and looses it then it's fine untill I turn it off :-? Does anyone have a clue what it could be?? Iv tried new ht leads new plugs and coil pack maybe a sticky tappet????? If so how do I fix it?
russ-RST
Re: Russ' mint green FRST need help again :/ lol
Postby russ-RST on Mon Nov 28, 2011 6:52 pm
Well iv figured it out now turns out was just a bad exhaust blow :lol: once I looked in daylight it was obvious lol :rolleyes: need to get new studs and a gasket and go through all the exhaust side and make it all 100% that's the plan ATM is just to go through everything on the car and make sure it's 110% before I do the next :)
Also thinking I need some new wheels not decided on what yet tho :rolleyes: I doubt il ever be able to save masses of money just for wheels but any1 got any good ideas?? ATM I'm thinking either vts wheels again or maybe silver/white 1.2's
russ-RST
Postby jonyb4 on Tue Nov 29, 2011 2:28 am
you know looking back at that picture mate its looking fudgekin stunning, do you go to many shows because you should (dont remember you at any this year)
its pretty unique in that colour being a full RS rep, at first i thought it look crap, but now you got the rs bumpers done too its very nice :aviator:
Postby russ-RST on Tue Nov 29, 2011 12:12 pm
jonyb4 :you know looking back at that picture mate its looking fudgekin stunning, do you go to many shows because you should (dont remember you at any this year)
I haven't been to any shows yet no :( iv been meaning too but never have the money when it comes to it :rolleyes: yea I think the colour is my favourite part of it ( and the waste gate chatter :Q lol )
I'm hoping to attend a few next year aswell as the ring for my 21st but I think it needs alot doing before both :oooh:
russ-RST
Postby jonyb4 on Tue Nov 29, 2011 8:03 pm
you should put some dosh away for the ticket and some little bit for petrol :)
ever been to one yourself without the car? i bloody love it, one of the best parts of the car world, just feels much better when you have a car there thats appropriate, even if its in the novice/junior league of fast fords :P
Postby russ-RST on Wed Nov 30, 2011 3:33 am
I think I will just so I can put si's to shame :Q :lol:
russ-RST
Postby russ-RST on Wed Nov 30, 2011 11:41 am
Small update
Well done something that's been bugging me for a while today:
Got bored off black calipers and I liked the look of my 1.3 ones
So started with these:
Weapon of choice
Excuse the sloppy painting skills :rolleyes: only brush I had was far too big lol
Nice and lairy :Q
And thought I'd be a bit of a tart :lol: used cotton buds to brush it on wish and wipe any excess off made it really easy and neat :Q
Need to get my FMIC and green boost pipes then tidy up wiring and the engine bay is done for looks, might redo the rocker cover, inlet and charge carrier?? Again as ain't a great finish and maybe move the battery to the boot later on?? And spray the engine bay mint green at some point
russ-RST
Re: Russ' mint green FRST small update
Postby jonyb4 on Wed Nov 30, 2011 4:19 pm
si's to shame?
just to clarify the "junior fast ford" comment was refering to my car, i sense you think i was having a pop at you?
funny how you commented on you thinking my brakes are small, yet yours are smaller than mine?
the green goes well :)
Postby russ-RST on Wed Nov 30, 2011 9:57 pm
jonyb4 :si's to shame?
Sorry bud was in a s**t mood yesterday :rolleyes:
They're standard RS calipers and iirc I can't get any bigger under these wheels once I get 15's I want 300mms :Q
Yea and matches the samco's almost identically in person :)
russ-RST
Postby bakewell001 on Sun Dec 04, 2011 5:27 pm
You were just following me and Toby in his golf. Hope you've sorted that brake pedal following that close... :P
bakewell001
Postby jonyb4 on Mon Dec 05, 2011 3:13 am
Postby russ-RST on Tue Dec 13, 2011 12:50 am
Yeah the brakes are fine! Got the servo done a few days after lol didn't notice you tho been trying to fix the car it's been running like a tank lately with a bad blow so new: leads, plugs, rocker cover gasket, ex mani gasket and new studs and nuts were fitted fixed the blow and ran smoother but still wasn't right, turned out the pins inside the injector plug on cyl.2 had been bent somehow and weren't making contact after all the faffing about going thru spark air fuel etc pushed the pins in plugged it back on and ran sweet :Q :rolleyes: I am in love again :lol: I will wash it soon and get some pics but the weather is crap :( also picked up some mudflaps and chrome boot lifters the other day tried on the mud flaps and they're about an inch very max off the floor :lol: and was thinking of fitting the lifters under the bonnet??? Not sure if it will look smart or chavy tho :-? Opinions??
russ-RST
Postby jonyb4 on Tue Dec 13, 2011 4:43 am
theres a kit out there for bonnet struts on a mk3, each ive seen are chrome, do look pants but people use them anyway lol
how the heck did you notice that bent pin! that would have wound me up
Postby russ-RST on Tue Dec 13, 2011 2:38 pm
I'm notsure on whether to fit them or not :-?
Process of illumination mate boost was fine so had air spark was fine so had to be fuel lol shame it took me untill I had the engine in bits scattered everywhere till I realised :lol:
russ-RST
Postby Minstral on Tue Dec 13, 2011 4:34 pm
could always spray the bonnet lifters so they aren't chrome. most newish dubs about 10yrs old or so have 1 lifter as standard. makes working on the car so much easier
Minstral
Your car: *
Postby Excursion on Tue Dec 13, 2011 10:10 pm
Love the painting skills :lol: Nice car.
