Russ' mint green FRST , update :) : Member's Gallery - Page 8 | Fiesta Forums
Re: Russ' mint green FRST :D NEED HELP!!!!!
Postby russ-RST on Sat Dec 25, 2010 10:31 am
that sounds exactly like the bolts i got from the scrappy but they are defo too big :( :-?
russ-RST
Your car: fiesta rs turbo
Postby frst toady on Sat Dec 25, 2010 12:20 pm
:-? O well dont think u'd reli want anythin smaller holdin the arb on tbh
it'd probably rip em out if any smaller :lol: i'l av a look see if i got anything similar in ma box of bits
frst toady
Your car: ranger super cab, frst t3
Postby rs220bhp on Sat Dec 25, 2010 2:24 pm
The size stated sounds about right to me.Why not swap the carriers for the ones from the white rs
rs220bhp
Postby frst toady on Sat Dec 25, 2010 3:41 pm
rs220bhp :The size stated sounds about right to me.Why not swap the carriers for the ones from the white rs
:lol: i hope so or i might have the wrong car :lol:
onli other thing can suggest is to put that size tap through the hole to make the bolts fit
frst toady
Postby russ-RST on Sat Dec 25, 2010 5:56 pm
i havent got the carriers off the rs and i suppose i aint got a choice but to tap em to the right size but that means taking of the carriers to do it properly dont it ????
russ-RST
Postby jonyb4 on Sun Dec 26, 2010 6:11 pm
frst toady ::-? O well dont think u'd reli want anythin smaller holdin the arb on tbh
theres only a twisting force acting on the arb, nothin much can rip the bolts out
Postby russ-RST on Sun Dec 26, 2010 8:35 pm
thats what i thought. so what should i do try and find some bolts to fit the existing holes or enlarge the ones on the car to fit the standard bolts?
russ-RST
Postby frst toady on Sun Dec 26, 2010 10:27 pm
jonyb4 :
russ if u can find some bolts wot fit the holes mate and your happy boltin em up there probably be ok
just my personall opinion bumpy roads/corners etc etc, as the m8x 1.25's aint massive by no means but thats wot was on mine so..
:oops: dont be so literall jon thats why theres a laughing face after the comment....bolts was made a size for a reason.....
frst toady
Postby jonyb4 on Mon Dec 27, 2010 12:27 am
i agree just try random bolts in the hols and find which one fits, if one is slightly too big/small try the next size, its a jigsaw piece fit :)
Postby russ-RST on Mon Dec 27, 2010 12:41 am
lol iv tried all of the bolts i have :-? :lol:
russ-RST
Postby frst toady on Mon Dec 27, 2010 12:50 am
:lol: :lol: u need a bigger box of old bits n bolts
av a look see if u can get a tap in there without dropping it all down it'll be tight but maybe do-able
frst toady
Postby jonyb4 on Mon Dec 27, 2010 1:11 am
and none of them come close? if you aint got the size buy some M6/8 and 10 bolts that are about 15mm long
Postby russ-RST on Wed Dec 29, 2010 3:55 pm
i might just whip them off at a later date and tap em to the size i want lol
russ-RST
Postby russ-RST on Mon Jan 03, 2011 4:57 pm
well not much progress here to report to be honest but i thought i'd share with you where i am up to so far and what's stopping me etc.
well basically i had a really bad xmas consisting of splittin with my missus on xmas eve the battery turning out to be cream crackered and then when i went to do the gasket on my oil return from the turbo i snapped a bolt :x so i havent touched the car since but i have a collection of parts and some motivation now and the fact i need my car before the 18th as iv got bloody jury service :x :lol: just my luck aye! :lol:
well i have a full set of gaz coilovers coming this week should be here before the weekend so this is the main update i have for the car :D so i can finally be sitting flat and some lovely lowness to go with :D
i will get off my behind at some point this week then and:
change the fuel pump as its still got the 1.3 pump in :rolleyes:
fit gaz coilovers :D
take off turbo.. send to engine centre to have bolt drilled out and then refit turbo with new gasket but this time without snapping a bolt :rolleyes:
once i have the car running again i will be taking it to my freinds to have the brakes fitted as i dont trust myself to bleed them and the 1.3 brakes aren't really up to the job :rolleyes:
then once these jobs have been completed (yes i will keep you updated) i have a few bits an bobs i bought for the car some time ago but thought i'd share them with you :Q
russ-RST
Postby russ-RST on Mon Jan 03, 2011 5:01 pm
mintex pads for the rs turbo calipers
my new drop links for the ARB these will get fitted once i find some bolts to bolt the ARB with :rolleyes: :lol:
my grooved discs for the rs turbo brakes :Q
new cambelt kit +tensioner and waterpump for the engine, again i dont trust myself to do this to my car so i shall be gettin a freind to help me do this
braided brake hoses for the new brake set up
as always there is alot more to purchase but i will write a list in a minute :) comments welcome
russ-RST
Postby russ-RST on Mon Jan 03, 2011 5:04 pm
the next things i shall be doing to the car are:
new top rad hose
some way of gettin the snapped pin out of my speed sensor in the gearbox :-? (any suggestions wlecome)
new engine mount and gearbox mounts as the gearbox mounts have defo gone and my crossover pipe is not hitting the bonnet when i let off :rolleyes:
fix small exhaust blow in mid section
find out why fan isnt working :-?
any suggestions or ideas on any of the above are more than welcome :)
russ-RST
Postby jayrs on Mon Jan 03, 2011 5:06 pm
if its the small platic drive pin from the speed sensor, then a pin may get it out if you stab it in and pull it out, depends how jammed in it is.
as for fan, what fan? rad fan or heater blower fan?
Postby russ-RST on Mon Jan 03, 2011 5:08 pm
jayrs :if its the small platic drive pin from the speed sensor, then a pin may get it out if you stab it in and pull it out, depends how jammed in it is.
that is a very good idea! why didnt i think of that :rolleyes: :bonkers: i shall try when i get off my arse and will let you know :wink:
and the rad fan buddy it never seems to come on although i'v had so many problems with the top rad hose leaking all the time i doubt it has ever got a reading :lol: thats a good point i must change the thermostat :rolleyes:
russ-RST
Postby jayrs on Mon Jan 03, 2011 5:34 pm
coulkd be the thermo switrch in the stat housing, then again it could be the plug that plugs on it, they tend to get pulled off by the wires and the wires break internally.
chech to see if the fan does work, it could be as simple as the fan motor has just burnt out.
im guessing you have checked the green relay already and cleaned the pins? if not, do that too
Postby fezza89 on Mon Jan 03, 2011 5:46 pm
what suspension set up have you got on the car now?
fezza89
Postby russ-RST on Mon Jan 03, 2011 5:56 pm
g-max shocks on the front with jamex 60mm all round
russ-RST
Postby russ-RST on Mon Jan 03, 2011 5:57 pm
and i shall give the whole system a check over folllowing your advice but for the moment i think gettin it running and doing the cambelt and waterpump and brakes kind of take priority atm :bonkers:
russ-RST
Postby fezza89 on Mon Jan 03, 2011 5:58 pm
are you going to be selling the gmax shocks?
fezza89
Postby russ-RST on Mon Jan 03, 2011 6:16 pm
i might consider it PM me if your interested.
russ-RST
Postby fezza89 on Mon Jan 03, 2011 6:20 pm
smidydevil :i might consider it PM me if your interested.
pm'd
fezza89
Postby russ-RST on Tue Jan 11, 2011 1:15 pm
well i have been suffering with swine flu lately so haven't been doing anything to the car for a while :rolleyes:
but i have just recieved my christmas present i bought for my self :D :D :D
yup nice set of gaz coilovers for the fezza :D :D now i can get the ride hieght sorted properly and having it sitting nice and low :Q :Q
hopefully if the weather isn't too harsh to me today and a buddy comes over to lend a hand i should have some more updates by tonight :Q
russ-RST
Postby frst toady on Wed Jan 12, 2011 1:12 am
how you got on with the coilovers bud
frst toady
Postby russ-RST on Thu Jan 13, 2011 9:54 am
well you'l have to excuse the dirt as i havent used the car in about 3 weeks and i just haven't had any motivation to do anything with it :rolleyes:
but yes yesterday i got the turbo off and fitted the coilovers, i havent set them up to the ride hieght i want yet but i did manage to grab a pic to show its already much better :D i will have to sort out the hieght i want today and will grab some more pics then :D
russ-RST
Postby frst toady on Thu Jan 13, 2011 2:07 pm
well ya gettin there anyway bud so its all gd :aviator:
frst toady
Postby bakewell001 on Thu Jan 13, 2011 2:12 pm
Getting there, just get those bumpers sorted out and it'll look pretty good.
bakewell001
Postby jonyb4 on Thu Jan 13, 2011 8:53 pm
uuuh im half and half aobut the colour and body kit/wheels
i liked mine in this colour but it was completely standard bar a mk4 wiper lol
maybe if i saw it in person, you attending any fo the car shows this year? :)
Postby russ-RST on Fri Jan 14, 2011 9:42 pm
well done some more work to the car today got the bolt out of the turbo and put everything back together although i'v rounded off one of bolts that bolts thru the exhaust manifould into the turbo :oops: so if anyone has a spare one of these id b interested lol and finished off everything went to start it but im having a blonde moment and can't find a positive wire to the battery :-? iv got 3 negatives and 2 postives but cant seem to find the 3rd :rolleyes: :-? its really wierd i know its there but cant find it :lol: any pictures off the wires connected up to the battery would be very helpfull as its doing my head in :-? can't seem to find it :(
russ-RST
Postby russ-RST on Sat Jan 15, 2011 4:14 pm
basically i cant find a missing positive wire to the battery iv got 3 negatives and 2 positives and im sure there are 3 of each :rolleyes: iv got the big cable coming from the alternator with like the cross head fixing battery end and the ingnition cable coming from the loom has about 4 red wires going into it i know theres another one somewhere just cant find it :-? can anyone explain/ put a pic up of there battery
thanks
welll took a few pics of the wires i have got and can find if anyone can point out where the missing cable should be or even explain to me where it could be :lol: its annoying [ERRR] iv taken the battery off a million times and yet all of a sudden i cant find the cables lol
these are the 3 earths i can find
and these are the 2 positives i can find, wheres the other one :-? :-? :lol:
russ-RST
Postby jonyb4 on Sat Jan 15, 2011 4:39 pm
looks fine to me
Postby russ-RST on Sat Jan 15, 2011 5:27 pm
im sure there are meant to be more than 2 positive wires :-? :rolleyes:
russ-RST
