Russ' mint green FRST , update :)
Re: Russ' mint green FRST small update
If I would have them it would be chrome or not at all the pnly chrome I'm having in the bay is my suspension tops and maybe these?? If not il chuck em lol
Yeah great aren't they alot better with spraying than brushing thanks still got loads left:new wheels,brakes,tyres, then power and gbox clutch flywheel etc. get it all sweet then respray or PDR bloke then might go ZVH
- russ-RST
- Your car: fiesta rs turbo
- Fraggle
Cheer mate it defo is
- russ-RST
when i had a green mk3 i could never see it looking like that
jonyb4 :when i had a green mk3 i could never see it looking like that
What you mean?
- russ-RST
as good as that you mean jony
well i thought to myself i aint bothering doing it up as i thought it look crap, if i had seen this back then id have been a believer!
Ah right thanks guys means alot progress is really slow ATM due to my temp job ending on new years and trying to save money for being skint again still got so much to do
- russ-RST
Corr, haven't checked this thread for a while but you've brought it on a long way, looks excellent
- Tweek
- Your car: VW Golf GTD
Tweek :Corr, haven't checked this thread for a while but you've brought it on a long way, looks excellent
Thanks man hopefully over Xmas should see a few goodies working there way on to the car the outside is basically done except new wheels and getting it minto , think iv made my decision on wheels just got to get the money together
- russ-RST
Re: Russ' mint green FRST sleight bufty session
Well yesterday I was bored and fed up with not doing anything cos of rain/snow (apparently) so I decided to do a few little jobs iv been wanting to do for a while now, first of all
Take one engine bay, now 2 things have always annoyed me here 1 how minging the header tank is and that I couldn't ever see how much was in it ,and 2 the mass of wires that run along the bulkhead, I have always thought this made it look very messy
First job remove the bottle
Glad to see no rust (yes it's just dirt I did clean it out to check before re assembly, now 1 minging bottle
Pretty horrid so I attacked it with a pressure washer and bottle brush
Also you can see it came up well altho I couldn't get into most of the chambers it is much better
Photos don't do much justice it is alot better than it was and I can even see the water level and colour of it
TBC.
TBC.
- russ-RST
The next thing I done was pressure wash off the bay as its filthy during this I managed to find a ratchet I thought I lost ages ago!
now before I tackled the wiring a few things had to be removed, the sensor under the edis module.. What is it??
It has a 3 pin plug that goes in and iv just found out iv never had this plugged in!
Anyway onto the wiring, I always thought you could hide it all behind the firewall with a few holes placed for wires to sensors, upon closer investigation I saw there was two rubber flaps at either end (water drain?) so I used these as the entrance for the loom to hide behind the firewall, and then only needed one hole after that and it all fitted, yes it clears all the wiper motor and linkage, it's a bit of a squeeze and could be made better if the box covered the heater motor was taken out/adjusted but I didn't want to mess with it, so remember the spaghetti junction I had before?
And now...
Now to sort out and hide the rest of the wiring and tidy up the bay a bit more, I might even wash it soon!
And now...
- russ-RST
I wouldn't recommend that mate: its new home is in an area that will always get wet and often retains moisture, not a good move with a ~20 year old loom
Capillary action due to surface tension means that water is drawn along wires for a considerable length, which is why alternator leads can end up corroding inside the sleeve by a meter or more away from the terminals.
you should have done the rice and cleaning product like cilit bang trick with the header tank mate, no offence but it doesnt look like much of an improvement compared to the effort removing it/bleeding the system
I retapped the loom before I put it there. It's defo water tight but thanks for the pointer I will keep an eye on it, and Jony I didn't have anything else to clean it with and it has made a massive different there just s**t pics lol
- russ-RST
....or you can just buy a fresh new one for £30
- Ratspeed
or my clean one for £20
There like 50 new Tbh mate cost me nothing to clean it il get some good stuff to clean it and do it again not spending money on a bottle
- russ-RST
using the technique ive seen people get them minty clean
mentos and bleach would sort it out!
and leave a minty yet sterile smell behind
- Michael!
Michael! :mentos and bleach would sort it out!
I will give this a go next as get paid soon
- russ-RST
bloody hell, they must have gone up in price. I bought one for my old blue mk3 and it was £27
- Ratspeed
Ratspeed :bloody hell, they must have gone up in price. I bought one for my old blue mk3 and it was £27
I haven't been into ford but they are 50 on eBay so id imagine ford is even more lol
Either way I'm not spending money on a bottle lol il try cleaning it again, if it doesn't work it can stay as it is lol iv got other things to pay for 'if it's not broken don't fix it'
- russ-RST
Put it in the dishwasher
- hb69
- Your car: Fiesta 1.1 LX
hb69 :Put it in the dishwasher
I haven't got one
- russ-RST
Re: Russ' mint green FRST ....not good :(
Well the snow hasn't brought me any luck was out in the car sat night and everything is running fine and normal, go to start it Sunday with all this decking snow :/ and it wouldn't kick in full throttle it just abouts gets to 500 odd revs whilst turning the key but won't actually kick over... Further investigation today
Iv been told to unplug the tps sensor and/or map sensor to see if these are faulty then check for air leaks etc. then your basic air fuel an spark and I'd they're all good then il get a compression test done although it shouldn't have frozen over
So yea not good news
- russ-RST
sorry to here about your poor running mate hope you get it sorted just a couple of questions when u did the conversion did u use everything out of the original frst and how easy was the full conversion as i wont to do the same thing with my 3.5 after my mk1 is done thanks adz
- Rs Adz
It's easy to do buddy il pm you
- russ-RST
Well had a little fiddle with the car today tried unplugging the tps and map sensor neither done anything, tried a spare coil pack and nothing, took the fuel pump fuse out and turned it over a little to clear the cylinders and then put the the fuse back in and still nothing....... running out of ideas now goin to check spark and fuel tomorow and my cambelt.
Anyone else got any ideas I can check ?????
I will get a compression test done soon aswell
- russ-RST
Excursion :I wouldn't recommend that mate: its new home is in an area that will always get wet and often retains moisture, not a good move with a ~20 year old loom
My advice is now more relevant than ever I would perform a continuity check on the loom.
Excursion :Excursion :I wouldn't recommend that mate: its new home is in an area that will always get wet and often retains moisture, not a good move with a ~20 year old loom
Il take that as a "told us so " How do I got about that I take it it involves a multi meter which I don't have
- russ-RST
Re: Russ' mint green FRST ....not good :( help needed
does it turn over properly
has it got enough antifreeze could be the pumps frozen
- jonboisescort
Car: 1994 Ford Fiesta
smidydevil :Il take that as a "told us so " How do I got about that I take it it involves a multi meter which I don't have
Ahh no I'm not saying that yet, but it's just a concidence that you moved the loom recently. If you're sure it's an electric prob then its' best to get a cheap multimeter and check all the ECU wires.
http://www.maplin.co.uk/domestic-multimeter-37279 will do fine for measuring continuity and resistance (check both as internal corrosion can make the continuity test pass but still be relatively high resistance). Be wary of meters with built-in cables and probes, they're often too short to be any use !
Nothing to see here...
- andymac
- Elite Pie Master
Yea it's got antifreeze in it but it has a leak from the rad so it doesn't stay in there long it does sound like normal when turning over but without it running lol, and ok is there anything else it could be before I check the loom? I'm going to check spark air and fuel today and check the cambelt and timing
- russ-RST
