Sat Nav Headunit help
Postby goaty on Sun Sep 17, 2006 12:30 pm
Hi,
i have one if these:
PIONEER ANH - P9R SAT NAV AND CD PLAYER
Its sat nav in the cd headunit, and i need a little help on the wiring. I have it all wired up but the sat nav doesn't work properly, but there are tow wires i havent connected.
One is a Reverse signal. I am guessing i could connect this to the reverse switch in the gearbox????
The other is a Speed input pulse, now i have read somewhere that this needs to be some sort of pulse signal to tell it your moving. I have been thinking mayb the flywheel sensor (crank sensor)?? but which wire out of them?
Does anyone know alot about these types of systems?
any help would be great, thanks
goaty
Postby butler_29 on Sun Sep 17, 2006 1:22 pm
i dont think ull need to fit any of them mate all u need is the gps ariel working and thats it i think. dont wori about connecting them to sensors or anything like that, waste of time and to much hassle.
butler_29
Postby goaty on Sun Sep 17, 2006 6:22 pm
well i have read somewhere that it wont work properly until they are, and using it yesterday, it either had no signal or sumthing else is wrong.
Would the crank be an idea though?
goaty
Postby goaty on Sun Sep 17, 2006 7:33 pm
just went out and had a play with it.
I can say the GPS signal is working as it gives me my Global position as i am moving along, but the system doesn't notice i am moving, like the Speedo pulse input tells it your moving and updates it.
goaty
Postby Priezti on Sun Sep 17, 2006 7:54 pm
you need the speed pulse to be connected, in a mk3 fez im sure its the green wire at the back of the clocks :)
Priezti
Postby goaty on Sun Sep 17, 2006 9:43 pm
are you talking about the large connector in the back of the clocks??
But yes the speed pulse is the one i need.
Green you say, is there only one green back there?
goaty
Postby Priezti on Sun Sep 17, 2006 10:00 pm
yes, yes and its a solid green to the right hand side of the plug
Priezti
Postby goaty on Sun Sep 17, 2006 10:08 pm
koo, will have a go at it 2mo and i just noticed your signature, so i am guessing you will be right.
I will let you knwo how it gos.
goaty
Postby goaty on Sun Sep 17, 2006 10:10 pm
mine is a mk3.5 if that makes any difference, 1994..........
and i have jsut found this site showing that a 1996 is Red/white in the A pillar kick panel. Not saying your worng just trying to help..
http://www.wvopzeeland.nl/Speed-signal% ... %20wire%22
goaty
Postby Priezti on Sun Sep 17, 2006 10:21 pm
dont think so
Priezti
Postby Priezti on Mon Sep 18, 2006 7:05 am
ignore what i said, thats the rev pulse :rolleyes:
i think i know where it is and the colour but ill double check later
got my wires crossed there :rolleyes: :)
Priezti
