Saturday's job - XR2 engine into MK3... any last minute advi
7 posts • Page 1 of 1
Got the XR2 parked in front of my 1.0 1990 MK3... stuck with driveshafts and wiring......
I stipped out everything from my 1.0, but one of the bolts from gearbox to engine slipped so i can't seperate them... What do i have to do to get the engine & gearbox out - in other words i have to remove the driveshaftrs but don't know how
the MK3 had carb, but electronic ignition. The XR2 has a distributor (keep me right here guys!)... so what will happen with wiring please?
Any last minute advice, or well wishes, greatly recieved!
- Jamie
not oo sure about the drive shafts mate but ive had a XR2 lump put in my Mk3 1.1hcs. the hcs was dizzy-less (so no coil etc..) but the XR2 engine uses a dizzy and coil set-up....
so i got a auto-electritian to do the wiring for the engine. only cost £50. he wired up the dizzy, coil, temp sender and rev counter.
i know nothing about `engine` electrics so if you are the same then dont even try and do it yourself if i was you.... Good Luck
The PhatFiesta
May she live in our memories forever
- PhatMan
- It's a bit of an Animal..!
Right to do this swap you first need the following
- MK3 CVH drivers side engine mount
- MK3 CVH Rad and all pipes
- MK3 CVH Distributer Coil and loom to coil
- Mk3 1.6s exhaust
The rest is straight forward, just use a crowbar to prise the drive shafts out the gearbox, undo the bolts between the shocks and hubs first!!! Drive shafts will be fine to use with a 1.6!!
worthwhile conversion mate!!
- Mk3 1.6s exhaust
- xrsi
- XR(ustyAtTheMo)SI
xrsi you mention the driveshafts being ok with a 1600i had 1100 mk2 shafts in my xr2 with an 1800 zetec turbo!!
- crazy dave
double post - I posted some randon 'gammon slipper in the other section for ya
(unless I managed to cancel the post, in which case, d'oh!)
Take it out and put the new engine in with the gearbox attached.
Good luck - Al
_________________
<!-- BBCode Start --><A HREF="http://st2000.s5.com" TARGET="_blank">Shed or Dead</A><!-- BBCode End --> • moop@st2000.s5.com • <!-- BBCode Start --><A HREF="http://st2000.s5.com" TARGET="_blank">st2000.s5.com</A><!-- BBCode End -->
<!-- BBCode Start --><A HREF="http://st2000.s5.com" TARGET="_blank"></A><!-- BBCode End -->
<font size=-1>[ This Message was edited by: Project ST2000 on 2001-11-30 20:10 ]</font>
Good luck - Al
_________________
- Project
- fiftyoneCL
