scuttle panel
7 posts • Page 1 of 1
scuttle panel
Don't mind if it's a new panel or cut off a car as long as the passenger side is free of rust. Getting fed up of the puddle in my footwell and I think the main culprit is the scuttle. Only panel I seem to be having trouble finding
- Christina
- Your car: '90 Fiesta Popular Plus Mk3
Re: scuttle panel
I have one Allready cut from a shell I broke, I will pm you some pics tomorrow
CheeRS
Chippy
CheeRS
Chippy
- chippy_rs
- Authorised Trader
- Your car: S2 RS TURBO
Re: scuttle panel
Excellent!
- Christina
Re: scuttle panel
You will probably find that the drain hole is blocked causing you issues, have a look
- reithy
Re: scuttle panel
I've had the carpet and insulation out to look around, even poured water over it, but still couldn't tell where the water was coming from. not much space under there either!
- Christina
Re: scuttle panel
Under the bonnet where the ecu is there is a drain hold that goes down into the wing, if this is blocked you will end up with water pooling and will find its way in
- reithy
Re: scuttle panel
I'll give it another look thanks!
- Christina
