setting up my zvh
6 posts • Page 1 of 1
setting up my zvh
i build my zvh turbo a couple of years ago now, i have never had it set up on the rollers.
i am runnig the standard ecu with a 195 chip beige injectors, piper 285t2 cam t3 turbo.
what do they actually set up? can they change the map on a stanard ecu?
1800 ZVH turbo on 18s
- neil_zvh
Re: setting up my zvh
They will setup the boost level and the fuel pressure and generally check the engine over for health. I wouldn't think an off the shelf 195 chip would be that suitable as it's not designed for a ZVH in mind. Setting an engine up really is an absolute must. At best you will not be getting the most from it and at worst you could potential cause some very expensive damage.
Am I right in thinking we spoke about this a couple of months ago Neil? As Steve says, the 195 chip isn't very well-suited to the ZVH, as we've seen on our rollers in the past. We would source a suitable chip from MSD, then check, assess and adjust (if necessary) your boost and fuel pressures along with your base CO level. There is a very realistic chance that your engine will be running lean past about 4,500rpm, which means that you could be risking the life of your pistons every time you floor it. There's also a good chance that your economy could be considerably better once the engine is running on a suitable map.
To give an idea of cost, a chip from MSD to suit your application would be £250, and setting it up on the rollers is a standard £125 fee for a turbocharged car, provided no additional work is required.
Thanks for you replys.
i dont think i ve spoke to you about it
i know what your saying about the 195chip its mapped for the 1.6 cvh not a 1.8zvh so it will not be right all tho it does seem to run very well.
i have been thinking about getting stand alone managment some thing like a megasquirt, am i right in thinking that would be more mappable than a mappable chip?
thanks again
Neil
thanks again
Neil
- neil_zvh
why go the long way round, and put new management in when you know you could get a chip done to your spec on your existing frst management
btw proffesional mapping alone costs between £400 - £500!
you could never know if your cars running well unless you have the fueling etc checked !!!! if i was you, id take it easy
- GavStyli
- Your car: Fiesta Turbo
we have similair spec engines here ie mine
i am in same boat too mine pops and bangs when not accelerating yet seems to drive and boost fine although it is actually on the std ecu as far as i am aware??? oh and it has dark green injectors.........
will track this topic and see what you do and what results you get as i wanna sort mine and make sure its running right
listening for costly strange noises????
- RS GEZ
