Shock Absorber
8 posts • Page 1 of 1
Shock Absorber
Well the rear drivers shock absorber has gone, I'm thinking of replacing it myself as I'm 18 and really should start learning these things.
..plus I can't stand paying garages to do something I could possibly do.
So.. how hard is it, how long will it take and are there any guides?
- Cheers, Aaron.
- Cheers, Aaron.
- fiend
Well, if you're replacing it with a new one I'd recommend replacing both sides. Easy job
1) Slacken rear wheel nuts
2) Jack up the rear of the car and place stands under the chassis legs.
3) Remove wheels
4) Unbolt the bottom of the shock, it'll be a 19mm (i think) bolt
5) Open the boot and remove the strut covers, unscrew the 2 13mm nuts holding the top of the strut in place but not the bolt going sideways.
6) Assuming the beam is not supported and hanging freely, push down on the drum and lift the base of the shock out and pull out on a slight angle to get the top out.
7) Using spring clamps, release the tension off the top spring cup and remove the bolt, if it's too tight after you've cracked it loose, you don't have enough spring compression.
8 ) Remove the spring and place it on the new shock, turning it so the end of the spring slots nicely into the groove on the cup.
9) Place the top cup back on (the right way) and put the bolt back through it then release the tension off the clamps
10) Reverse steps 6 to 4
11) Repeat whole proceedure for other side
12) Refit wheels and lower car back to the ground.
That's it, shouldn't take you long at all, longest part will be compressing the spring(s) lol.
3) Remove wheels
- Tweek
- Your car: VW Golf GTD
Awesome, cheers for the guide! I'll do them both on saturday if the weather is good.
How long will it take?
I actually was just reading through an old issue of Fast Ford and its got a full guide [with pics] on fitting coilovers which shows how to remove the shock absorbers. Which will come in handy too .
Another quick question, are XR2i shocks different to a normal fiesta?
- fiend
XR2i shocks are gas filled and so are stiffer than lower spec Fiestas which are oil filled. As for fitment the rears are the same but on the front the sports models have the tab to fit the anti-rollbar dropling to.
I bought a pair of rear XR2i Unipart shocks off eBay for £25 posted so they're pretty cheap, and they worked lovely with Spax springs too.
The time it takes depends on how quick and competant you are and what tools you have. I'd say give yourself an hour.
- Tweek
Ahh thanks for the info, I will hopefully be able to borrow a set of spring clamps and axle stands off a friend.
I've got a decent sock set, allen keys etc plus my Dad for help if I need it.. just need the good weather on saturday!
My suspension is all completely standard, will have a look on ebay for a set of shocks. I'm tempted to put some aftermarket springs on though.. hm.
- Cheers Aaron
- Cheers Aaron
- fiend
- Tweek
- Tweek
