Si air filter
6 posts • Page 1 of 1
OK I'm probably going to get laughed at for this, but...
A K&N induction kit works by allowing more air into the engine, right?
So, for a cheap alternative, if I was set loose on my standard Ford air filter with, say a drill, and I made lots of holes; would it let more air into the engine and make it a little more responsive, just like K&N?
Gav
- Gav
Drill the airbox not the filter, and make sure the holes are only on the unfiltered side - you must have properly filtered air going into the engine esp with the 16v engines cos they don't like crap being bounced around inside them one little bit.
K&N might do a replacement element for the Si which will be less restrictive than the standard kit. Btw, most people report the Si sounds a helluva lot better with an induction kit, although it may run a little less well.
- Project
- fiftyoneCL
- Phil Si
Car: 2000 BMW 330 Ci
