Signature
14 posts • Page 1 of 1
Signature
Why do I allways have a bit of my sig missing at the bottom
My Sig's 300 x 100 and 19kb, so it sould be ok shouldn't
- Low Down And Dirty
- Location: Andover ish Drives: RS1800 and Overfinched Range Rover
It's only my sig I can't C all of, evryone elce's is fine, and my firewall's nearly none existant, I let any old s**t through .
The sig boxes are now meant to be limited to 400x100 by a script however some did go funny hence i believe some needed to be manually set to this size. PM AdrianFRST and he will sort this for you.
- chumkila
- Dirty Post Whore!
Low Down And Dirty :Cheers Ya'all. I'll PM Adi
no point. there isn't a problem, and each persons sig box size cannot be changed individually.
your sig box is 150pixels (or summert like that, i can't remember properly) high and thats your limit. if your sig is 100 pixels high and you have 4 lines of text above it, thats gonna puch your limit and make some of your sig be hidden.
so either take that text out the top of your sig, or make your picture smaller in height so it will all fit in the box.
- chimp2k2
SPo0n :i managed to get that huge mcdonalds pic working somehow it was way over those stated sizes
i can also get around the size thing (spoon, don't say how cause everyone will do it ) dunno why it does it though
- chimp2k2
Hell Fire :I have a bit of a problem with my sig too. its has a bit missing off the bottom as you can see. if was like that to start with then i made it smaller and its its got about half a cm missing.
lookie \/
well seeing as the rules say it should be no bigger than 100 pixels high, and yours is 130 pixels high, that would be why it gets cut off
- chimp2k2
