Single wiper conversion!
11 posts • Page 1 of 1
best thing to do is buy a storm single wiper kit for just over £100, but they're quite hard to fit. Don't bother bodging your existing wiper to a single one as the sweep isn't big enough and you'll fail your mot
LoW MoToR
- zetec69
Rob is quite correct the sweep can be altered but I really wouldn't bother as it can lead to some problems.
Get a Storm wiper kit like mine, they ain't that easy to fit but I got mine on in just under two hours. If you need a hand let me know
- Paul RS1800
- Blue Thunder
You shorten a bit, not the linkage but the bit on the wiper which the linkage joins to??????
Fcuk it I dunno, I downloaded a file on how to do it though as soon as I get some bloody time off work I'll get down the scrappies pick me self up a straight wiper arm (306 Rear) and then sort it!
- Robz_Fester
I put the motor out an AX with a custom wiper. However, the hole in the middle of the scuttle pannel for the wiper is not centred it is about 1.5 inches out so i cut the section out and moved it then re welded it using a section out a donor car. Probably too much fan*ying about but it pis*ed me off cause it didn't look in the middle of the screen.
Cubby
_________________
<!-- BBCode Start --><A HREF="http://www.cathburncustoms.co.uk" TARGET="_blank">www.cathburncustoms.co.uk</A><!-- BBCode End -->
<font size=-1>[ This Message was edited by: cubby240 on 2001-07-26 04:24 ]</font>
Cubby
_________________
- cubby240
