slim line fan
16 posts • Page 1 of 1
slim line fan
im buyin a suck type slim line im going to put it behind my pace rad i have two questions tho will a single 12inch one be good enough and will it clear my t3 i also have a grs front mount so can put the rad foward any info would be appreciated
- stevo™
Re: slim line fan
anyone?
- stevo™
Re: slim line fan
I doubt it will clear the turbo Idealy you need a blower mounted in between the rad and cooler. try this link they sell slimline fans only 2" deep. http://www.autospecialists.co.uk/
- matty872
Re: slim line fan
yeah mate ur never gonna get it on the inside of ur bay with a t3. i had the same trouble i spaced the rad forward abit as the t3 act touches the rad. iv ordered vibratechnics to help stop the engine moving so it dont get my rad. then iv fitted a pro alloy front mounted intercooler custom mounted leaving me 56mm inbetween the rad and intercooler to fit my 52mm 12"blower fan to be honest i wish i had fitted a xr2i rad so i could fit more fans but maybe il do that in the future
- rs-tom
Re: slim line fan
- j7aoc
Re: slim line fan
j7aoc :Spal are the thinest one's there around 52mm and it's easyer to put them in between the rad and intercooler i would use a blowing fan as your car will run loads hotter and as your driving it with blow air through the rad the same way the cold air is flowing and buy a 82* thermosat im using a 75*
What size fans are you running? I need to upgrade mine as I only have a 8" spal at the moment
- matty872
Re: slim line fan
The one on the left is a spal copy and is 11" around 52mm think and my car was still running hot so i found the one on the right off ebay which is a real spal fan aroun 8" which was off a motor bike it they come on some as standard
- j7aoc
Re: slim line fan
so best place for it is inbetween and to get a blower would one 12 be enough?
- stevo™
Re: slim line fan
mixon don't think that would work for him as he's running a t3. stevo i would say yes or try and get 2 10 inch one's if they fit
- j7aoc
Re: slim line fan
would two 12s fit if not il go for a 12 and a 8 like you
- stevo™
Re: slim line fan
Mine right on the edge so i woul say no 2 9"inch would be about rightstevo™ :would two 12s fit if not il go for a 12 and a 8 like you
- j7aoc
Re: slim line fan
j7aoc :mixon don't think that would work for him as he's running a t3. stevo i would say yes or try and get 2 10 inch one's if they fit
Ah right didnt see that. If you sticking with the smaller size rad, then i'd go for a setup like j7aoc. The standard fan is very good, I know it looks abit odd with two different size fans but its a good setup. Replace the thermosat as well.
- JamieFRST
- Keep It Tidy
Re: slim line fan
il get a 12 and a 9 then and i already have a new thermostat waiting to go in
cheers lads
cheers lads
- stevo™
Re: slim line fan
You need a longer rad (full width) if your going to block direct air flow with an intercooler infront.
- luca
