Smoking engine
Smoking engine
Postby Richy p on Fri Nov 15, 2013 5:34 pm
Hi all don't use car much and its been stood for 2 weeks without being ran anyway been out to wash it and start it up and its started puffing blue/white smoke out. However once engine warmed up it stopped and no smoke. Left car overnight went out started it up tonight again and once again smoking when cold but stops when warm? Any ideas?
heres some pics.
Richy p
Your car: 1990 FIESTA RS TURBO (RED)
Re: Smoking engine
Postby FRSJON on Fri Nov 15, 2013 6:01 pm
id take it for a spin and see if it smokes at different times..i.e hard acceleration,overrun etc.. it will either be valve stem seals,turbo,rings or a breather..also what grade oil do you use ?
FRSJON
Re: Smoking engine
Postby Dave5300 on Fri Nov 15, 2013 6:59 pm
same as mine mate, oil seal in the turbo is gone, when you start it will it take about ten seconds before it starts to smoke?
Dave5300
Re: Smoking engine
Postby Richy p on Fri Nov 15, 2013 8:09 pm
Dave5300 :same as mine mate, oil seal in the turbo is gone, when you start it will it take about ten seconds before it starts to smoke?
Does yours stop smoking when engine is warm though? Mine smokes immediately on start up but stops when engine is warm and does not smoke when revved etc once it is warm.
Richy p
Re: Smoking engine
Postby Dave5300 on Fri Nov 15, 2013 8:54 pm
mine starts smokeing about 8-10 seconds after starting, goes away after about a minute or so, and dosent smoke when warm
Dave5300
Re: Smoking engine
Postby snake on Fri Nov 15, 2013 10:41 pm
Stem seals have gone hard, oil goes down onto the valve after sitting and burns it on start up. Easy fix you don't have to take the head off.
snake
Trainee Burger Flipper
Your car: ford
Re: Smoking engine
Postby mikeymikeyp on Sat Nov 16, 2013 3:24 am
Stem seals mate ,, the tool to do them aint dear but if your buying new ones get "" top hat "" ones much better than original ones and the tool lets u do them without taking off the head
mikeymikeyp
Re: Smoking engine
Postby mikeymikeyp on Sat Nov 16, 2013 3:27 am
mikeymikeyp
Re: Smoking engine
Postby mikeymikeyp on Sat Nov 16, 2013 3:31 am
You can make a tool out of an old rocker arm if ur a stingy baxtered like me
lol :lol: :lol:
Ill get a pic of mine tomoz buddy :) :)
mikeymikeyp
Re: Smoking engine
Postby Richy p on Sat Nov 16, 2013 8:11 am
Cheers guys ive bought the top hat seals from fleabay so will give it a try and see what happens. :)
Richy p
