Soft Brakes???
3 posts • Page 1 of 1
Soft Brakes???
Hello! was just wondering if anyone knew the problem and how to fix it, my brake petal is really soft and brakes really unresponsive? any ideas?
thanks
thanks
- rtlee88
As said, check hoses, they might be flexing and need replacing. Also Brake fluid needs changing every 2 years, most peeps dont do it, but what happens is, its starts to compress within the pipes and not push your pistons out giving you a crap pedal, also air in the system can cause a spongy pedal. If you do all this and its still the same, chances are the master cylinder is on its last legs.
- MikeyXR2i
