Someone good at wiring !!!
Postby mick34123 on Fri Jul 18, 2008 11:18 pm
Does anyone no what wires are what coming from the dash where u connect the stereo/cd player 2 on an Fiesta mk4 1.3 e.f.i which is a n reg as the C#NT that had the car before me has cut the connector plugs off :x cheers.
mick34123
Re: Someone good at wiring !!!
Postby 6580durra on Sat Aug 16, 2008 11:58 pm
On the cars loom:
Red - Live from battery
Yellow - Ignition
Black - Earth
The rest on this plug are for the steering wheel controls if the car has them fitted
There should be eight speaker wires, four with solid colours, and four with the same colours but a grey strip aswel. Im not sure what the colours are, or which speaker they are for, but for example, the green solid wire will be the positive for a speaker and the green wire with a grey stripe will be the negative for the same speaker. Just power up the Head Unit and poke about with one on the outputs till you find the right speaker!
Its more or less exactly the same for every car. I hope this helps. Ill find the diagram in my haynes manual for my MK3, it will be the same, ill try and post it tomorow. Message me if you have any problems.
P.S. You should be shot if you can't identify the Aerial! :bonkers:
6580durra
Postby dontpannic on Mon Aug 25, 2008 9:11 pm
