speeding up a 1.3
22 posts • Page 1 of 1
speeding up a 1.3
hi does any 1 know of any upgrades i can add to make my 1.3 to make it go faster? ive recently bought an exhaust which im waiting for, is there any other things?
- Darth Maul
Stoned :Waste of time. That engine wasn't built for performance
In fact it wasnt apparently built for economy either... what WAS it built for other than make large amounts of clatter
to give the owner a life time or hardship paying to repair it
- nick050
It was built, well, designed in the 50's, and then Ford decided they should continue using it, just giving it a slightly different name every few years, up until the turn of the 21st century. Its a marvel of engineering really, but yes, it wasnt designed with performance or economy in mind.
So yes Mr Maul, you'll have a hard time with that engine. You can source modified cylinder heads, performance cam kits, uprated carburettors (if you have an older car), modified distributors etc etc. But at the end of the day, its a 1.3, you could have installed a 1.6 CVH by the time you got past fitting a modified carb. Go for a larger engine, and the insurance company are less likely to sting you than if you modify your current engine.
- Pez
i heard decatting it does abit but its not really worth it
6 Point Safety Devices Cage.
- purple_fiesta
Buy a lawnmower that would be faster than the 1.3
- TomRS1800
Aside from the obvious "cliff" comment, I feel it's worth pointing out that the Kent and subsequent Kent Crossflow engines developed in the 50s and 60s aren't what's in the 1.3 fiestas. A 1.3 crossflow would be a damn sight quicker than a 1.3 HCS/Valencia/Endura type engine. Although I suppose they might share one or two visual similarities, they AREN'T the same, and the Kent crossflow is a beautiful little engine, whereas the HCS is just... eugh.
- MotorcyclesFish
- Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
Re: speeding up a 1.3
Darth Maul :hi does any 1 know of any upgrades i can add to make my 1.3 to make it go faster? ive recently bought an exhaust which im waiting for, is there any other things?
remove the CAT and fit free flow exhust, K&N air filter, service it.
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm ), focus inlet in, + k&n, passed mot without a cat < FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW
http://www.finalgear.com
- VUK
We don't want to know what you get upto with your school girlsMax M4X WW :Mines slow, but i can still have fun in it! Hmm
- j7aoc
can confirm decat will have no effect, i didnt feel any real world difference anyway.
the downpipes are well designed and changing them would have negative effect.
you can port polish head with new cam etc, but you'll be lucky to see another 15bhp even with aftermarket management to take advantage of it. add to that the cost and hassle you would be better getting a bigger engine and paying the higher insurance
- FezzR
- God Damn Lazy
i voue for the fact that the hcs is s**t, mine does bout 190 mies to £30. er 0-60 in about 14 seconds, 12 downa hill, cant climb hills to save its rather worthles life. can still beat ma m8s 1.4 16v ibiza of the line and round corners tho which is a plus. thankyou spax and proxes.
- Jonezy
For all the stick the engine gets, I never ever ever had a problem with the HCS Fords I've owned (well - not with the engines anyway). Good old workhorse - they were designed with economy in mind, but economy back when it was made is different to economy now. They were designed to power shopping trolley cars and therefore weren't meant to be powerful.
- andyhardy
andyhardy :For all the stick the engine gets, I never ever ever had a problem with the HCS Fords I've owned (well - not with the engines anyway). Good old workhorse - they were designed with economy in mind, but economy back when it was made is different to economy now. They were designed to power shopping trolley cars and therefore weren't meant to be powerful.
Totally agree,and, they just never give up(hardley). Despite the rattleness,and sluggishness,they keep on going no matter what you throw at them.
A friend of mine had a 1.3 sx(the sportyish fiesta), and we setup the carb, set the tappets,give it a good service and it flew for what it was, i still to this day cannot get over how nippy it was.
- XRMike
good for over the ton quick enough for me for now
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
I think the majority of peopel will suggest an engine upgrade would be better for you than modding the 1.3. A conversion to a 1.6 cvh or zetec should be noticably better for you.
In fact, if you're on a budget, upgrading to a 1.6 zetec makes a certain amount of sense as it'll be relatively cheap to insure but does mean you'll have the infrastructure in place to upgrade to a 2.0 later on when you can afford the insurance and are used to the additional power you'll find in the zetece engine.
You can try pm'ing xr2i chick or mmogenius if you want, I'm pretty certain paul (mmo) has a couple of 1.6's kicking round
Nothing to see here...
- andymac
- Elite Pie Master
MotorcyclesFish :Aside from the obvious "cliff" comment, I feel it's worth pointing out that the Kent and subsequent Kent Crossflow engines developed in the 50s and 60s aren't what's in the 1.3 fiestas. A 1.3 crossflow would be a damn sight quicker than a 1.3 HCS/Valencia/Endura type engine. Although I suppose they might share one or two visual similarities, they AREN'T the same, and the Kent crossflow is a beautiful little engine, whereas the HCS is just... eugh.
ive got to say that the kent crossflows are in fact fantastic little motors
they have a whole host of tuning goodies due to them being used a lot as
rally motors int the late 70's and are still used today
ive got one in my kit car and they dont make nearly a tenth of the tappet noise as a hcs
- edders
endura 1.3 tunning
hello, i recently bought a ford mondeo ghia diesel turbo kit with garrett .30 .48 for my fiesta endura-e 1.3. now im searching for forjed headers. if someone have any opinnion with this proyect please write to me. thanks ignacio desde argentina
- narcho
I thought the HCS was a diesel, or does it just sound that way?!? lol
if I got a pound for everytime someone came up to me in a petrol station and said "you do realise thats petrol you're filling up with don't you?!?" well id have enough cash for a diesel engine transplant!!!
In all fairness the HCS engines are awesome. Ok they couldnt pull the skin off a rice pudding but boy they would run forever. I used to drive mine down to bournemouth every weekend flat chat (managed 110 once down a really big hill in the slipstream of a merc kompressor ) so it cant be all bad!
And one of my mates once drove his on two cylinders for nearly 2000miles due to a broken rocker shaft! Replaced it with one from a scrap yard+recommeded lollypop stick tappet clearances=only about 3bhp but yes the car is still running!!!!! AMAZING!!!
in fact its nearly tempting enough to drop the 2.0L and replace it with a 1.3 HCS.......... Naaaaaaaaa
- harris-hpe
