st170 brake conversion
2 posts • Page 1 of 1
right i need new brakes and seeing as im gonna get a 2.0l zetec at sum point i mite aswell get st170 brakes. now my fiesta has abs so will i jus need calipers, discs and pads or will i need more?
any help is appreciated!!
- chris-fiesta
that should do the trick mate. all you need to do is to drill the hole for the bolts on the hub from 10 to 12 mm as the bolts are bigger.
And you need a 2-3mm washer on the bolts aswell.
good luck. I have just fitted st170 brakes on my 16v xr2i.
cant wait to test them
94 Ford Fiesta 1.8 16v xr2i
- Pisko
