Stage 2 spec???
3 posts • Page 1 of 1
Stage 2 spec???
Now then, im new here and my cars just blown up
but now im gna stage 2 spec it
my car is stock apart from zorst, cone filter and t25 hybrid,
what do i need for stage 2 spec, just beige's and power chip? or do i need a better fuel pump? or even lower comp pistons?
would i be better of going stage 1 spec first as tht just involves a chip?
say i get it all stage 2 spec do i need to mess around with the actuator sumhow and will it need to be ran on a rolling road to be set up? or wil the pre programmed chip sort itself out?
CHEERS GUYS
CHEERS GUYS
- eddyrst
a lot of the stuff you mentioned is right. you will need a chip, better injectors,probably a better fuel pump, and depending on the levels of boost youll be running you might need lower comp pistons as well. also you didnt mention anything about the head. i think this is just like a ported,polished( wow is it me or does that word look dodgy?) and larger valves.
also if you want it running well you will probably want it rolling roaded and setup properly by a recommended firm (ask around theres loads on here).good luck with the build
oh and btw where you from mate
- edders
hi mate, cheers for the reply, im from Grimsby, lincolnshire, havent had the car long, got raped by the insurance [ERRR] im only 17 but yeah hoping to either rebuild this engine to stage 2 or get a new engine,
where bowts you from mate?
- eddyrst
