stainless steel exhaust
13 posts • Page 1 of 1
hey all
I am wondering how much is this exhaust worth and is it any good: http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... RK:MEWA:IT
I will try to fit it to my L reg 1.1 fiesta,
what you think
what you think
- VUK
i didnt think stainless exhausts went rusty and it would slow yor car down anyway you need all the back pressure you can get
- xr2itrojan
are they both carb and its because your l reg has a cat. get a de cat pipe or better yet get a 1.6 sport or xr2 engine i wouldnt bother with anything less theyre just as slow
- xr2itrojan
Its crap about back pressure, as a cat causes plenty of it You want as free flowing as possible. its when people use a bore size not suited to the amount of gasses that will be pumping out of the engine. Exhausts work the best on the principle of the hotter the gasses the less dense they are which means they can exit the exhaust quicker but when people use a too big of a bore the gasses can be slowed down and become more dense meaning there is more to push against to get rid of the gasses, thats why some people use exhaust wrap and ceramic coatings. I'm pretty sure the that the standard bore is 1.75" on the 1.1 whereas it would be 2" on the Si/XR2i/RS1800.
The 1994 Fiesta would be CFi not a carb (still looks like a carb though). Also the 1994 would probably have the air pulse system which causes a restriction in the manifold but the main cause of restriction is the cat.
Stainless steel can take the appearence of rust but its mainly stuff like road salt and dirt etc baking on to it to give the look of rust. Also lower grades of stainless steel, like T409 still rusts.
HTH
HTH
- krsi
I know mate, I wasn't trying to knock your advise. Sorry if I sounded a bit off. I'm also only trying to help I not claiming to be an expert either, just trying to pass on what i know to help people out
- krsi
a company called jp will make you 1 and post it to you can't remember if there in macclesfield or glossop but search on lycos and they've got a website. my mate got 1 for his clio valve and it sounded sh*t hot.
- xr2itrojan
