standard 1.1 to frt brakes?
10 posts • Page 1 of 1
like the title says, ive been given the rst brakes, wel, the calipers, are they worth the effort of putting them on? theyve been reconed up a bit aparently.
whats the smallest wheel i will be able to get over them once on?
cheers guys
cheers guys
- m3matt
Re: standard 1.1 to frt brakes?
As I've said before you will regret it unless atm you are experiencing a lot of brake fade.
bigger-better-brakes-vt166793/
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
so i wikll see no improvemt? in all fairness, ive just had my brakes redone, and there pretty damn good, just want to av somit a bit larger!
- m3matt
My personal opinion is that the solid discs and calipers have a better bite, of course with the low weight engines. There will be NO benefit of upgrading to ventilated unless you have to dissipate lots of heat at the the vented ones are the SAME SIZE, just vented.
- Ollybee
As above, only worth doing if you hammer your brake pedal lots.
- Tweek
- Your car: VW Golf GTD
lol, well, im very sensible hehehe!!!
so the rst brakes are the same diametre, they are just wider to allow a vented disc?
does this mean they will fit behind y 13" rs alloys?
thanks for your help guys.
- m3matt
They will, if do you upgrade, make sure you upgrade the master cylinder as well, other the pedal will feel terrible.
- Ollybee
to be fair, as tempting as it is to put rst brakes on, its seems a lot more hassle than its possibly worth?
sorry to keep asking questions, im inquisitive but would i have to upgrade the master sylinder as it simply would not have the power to push the calipers together?
also, what would you recommend then as a decent brake setup?
thanks for ya help! (again!)
- m3matt
The standard fiesta master cylinder is 19mm and the high spec one is 24mm, so it moves more fluid with each pedal press.
Ideal setup would be, below 100bhp; standard solid disc setup. 100-140bhp, larger rear drums and ventilated fronts with high spec master cylinder. Anything more, Escort Cosworth 300mm front discs and standard large rear drums with Escort RS master cylinder.
- Ollybee
