Standard oil cooler
2 posts • Page 1 of 1
Standard oil cooler
I've got a standard RS oil cooler bolted to my RS block but I'm using a carb inlet manifold and not the RS one. I believe that one of the pipes from the oil cooler went into the RS inlet manifold.
Is there any other way I could use this cooler without having to put the pipe into the inlet.
Could I do the below:
- Escort Cos
the pipe that went to the inlet manifodl was actually a water pipe not an oil pipe.
remove the standard sanwhich plate oil cooler and replace it with a mocla sandwhich plate !
- MadcatCraig
- BANNED SELLER
