STEERING ADVICE URGENT
6 posts • Page 1 of 1
i hit a kurb today at about 30mph, i was cut up by a new golf gti!! arrgghh in my 2.0 litre si, i had 2 flat tyres after replacin them my car is ok but wen the alloys are pointin str8 the steerin wheel is facing left an im wunderin [ERRR] is rong?? if it is expebnsive i may nbreak the car if there is enuff interest thanx
- bigtazzsi
30mph impact you have almost certainly buggered the wishbones and the tracking will have been pushed out. Wheels will almost certainly no longer be properly round and if yo are unlucky you may have damaged the pick up points for the wishbone. Could have also damaged the shocks.
Only way to tell is to get under it and have a damn good look. TBH even if the wishbones look ok I would be inclinded to replace as a matter of course.
Check check and then check again you don't want to find a component was damaged when travelling at 70mph
2.0ltr si - sounds quite a bit of money has been spent already so I would'nt be quick to break it . Laser tracking cost me about £30. You could bring down the cost of repair by doing the wishbones yourself. Wishbones cost about £25.
I'd take it to a garage who will check it for free and give you a quote on exactly what's wrong and if it's worth repairing
- chris21
Was it both fronts that took the impact or just the side two?
If the rear took a bang you will want to check the beam didn't bend.
