steering problems :(
Postby davis89 on Sat Jun 08, 2013 3:43 pm
just bought a 1.1 n reg 3.5 fiesta as a daily...seems a good tidy car...on the way home began to notice the steering was quite tight turnin left and the tracking was out...having had a look the next day the n/s wish bone as been replaced yet i have a old tatty one on the o/s (god knows why you'd only replace the one lol) also the tie rod ends are fooked so iv replaced them..some of the gaiters do look just split on the rack...also noticed a droning noise now when i turn the wheel straight from the left at slow speed...i honestly think its been bumped at some point...i aint a clue where to start to be honest...i dont ant to be buying bits for no reason..i no its hard to pin point the problem without seeing it or hearing it but if someone could point me in the right direction i'd be greatful :)
davis89
Your car: fiesta rs turbo
Re: steering problems :(
Postby frst toady on Sat Jun 08, 2013 4:16 pm
Checked the wheel bearings?
frst toady
Your car: ranger super cab, frst t3
Postby davis89 on Sat Jun 08, 2013 4:34 pm
i aint yet..but that as came across my mind for the drone maybe?i dont understand why my steering is so tight?its awful to drive :/
davis89
Postby fiend on Sat Jun 08, 2013 8:35 pm
Lower UJ is likely to be the cause of the tight steering.
fiend
Postby mikeymikeyp on Sat Jun 08, 2013 9:23 pm
Is it power steering if its manual the uj is the usual suspect most of the time they don't return when turning a corner what happened with the tracking
mikeymikeyp
Postby davis89 on Sat Jun 08, 2013 10:42 pm
when you guys say the uj am i right by thinking the knuckle that mk3s are prone for?i have actually thought that but thought it would be diff with a 3.5
davis89
