Still got this damn problem...
3 posts • Page 1 of 1
Shoudl i try swapping every thing like MAF ECU TB Injectors... over to RS1800??? Only i really need to find out why its not pulling right!
- unknown_user
Is the car holding back? if so do you still have labna sensor in exhaust? i had a problem were wiring was fautly to the sensor so it was letting loads of fuel run free causing car to lose loads of power,once wiring fault was repaired it worked fine (bearing in mind i only had a 1.1 engine in at this time!) worth a try!
- zetecrs
yea its hld back big time... although im prity sure its not a lambra sensor.. but i might have to change it to be sure?
- unknown_user
