Stock Fiesta Card Speekers Or Chep Things?
12 posts • Page 1 of 1
Hey just wondering if i should buy a cheep ass set of front speekers or leave the card foord ones in.
Realy need a beter job...
- JohnBoy_DIY
- Your car: CAR
if your not bothered about sound then keep the standard ones, if you want a better sound then go for some different speakers. 5.25" should fit in perfectly, you can go to 'maplin' electronics and get a pair from there, i paid about £9.95 for my pair for my old car, but they were on special offer.
- ~ John Reid ~
lol i am verry impashent and decided to go ahead with it anyway.
got myself some JBL GTO527's
Decided it was worth it aslong as there ar no theaving chives around.
[img][img]http://www.fiestaturbo.com/forums/gallery/JohnBoy_DIYPicture(30).jpg[/img][/img]
- JohnBoy_DIY
- Your car: CAR
i got a pair of kenwoods sat where the old ones wereno difference on the outside but a million times better sq than stock
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
got to wate till fri to get a mounting bracket but i have run all the wireing and removed the old ones.
- JohnBoy_DIY
- Your car: CAR
Get some Dynamat and stick it on the door skin behind the speaker as this will reduce the sound being transferred to the door skin as vibration
~ John Reid ~ :if your not bothered about sound then keep the standard ones, if you want a better sound then go for some different speakers. 5.25" should fit in perfectly, you can go to 'maplin' electronics and get a pair from there, i paid about £9.95 for my pair for my old car, but they were on special offer.
I got some Pioneer jobbies from some Garlands, nr Lewisham, cost me £28 and they are f*cking brilliant. I had those £9.95 ones from maplin for about 2 weeks before they blew, but these ones are louder, bassier, and more colourful!
I normally use the old £9.95 ones to stick to the roof (magnet) and listen to cd's/radio/ipod while I'm fiddling with the car.
One tip - don't buy super cheap. I had to replace my standard speakers, cause the cone lining had seperated from the plastic and caused some really annoying vibration...
Nick
- dontpannic
I have partially dynamatted (extreme) front doors but really can't hear much difference in sound. I just bought the speaker kit for about £15. It supplies two pieces which are put around the each speaker, but as i said difference is minimal, perhaps i just need more of the stuff
The JBL speakers should serve you well, i had their old coaxials (526) up front and they were pretty decent, although i've since upgraded to JBL components and put the co-ax's on shelf. A sound investment regardless no pun intended
The only thing that bugs me about their new range is that they all run two ohms, i actually bought the old 4ohm model comps as apposed to the new ones, as i'd be surprised if an intenal HU amp is two ohm stable. Perhaps i was just being too cautious though, hope they give you no problems.
- richard_p88
Just chucked em in on my lunch break and they sound and look good so hopefully they will bee ok
gona get a pic up lata tanight
anywaze im bak off ta d some more paintin
- JohnBoy_DIY
- Your car: CAR
