Stray plug!
Stray plug!
Postby Mattious on Sat Dec 07, 2013 3:05 pm
Hi chaps,
Began to re install the FRST loom today, thought I had clipped everything back together , tried firing her up , no fuel pump prime , no dash lights or heaters , found this plug not plugged in ?? Just wonder where it lived as I can't find it's home !
Any clues???
Mattious
Your car: Fiesta rs turbo
Re: Stray plug!
Postby mikeymikeyp on Sat Dec 07, 2013 8:27 pm
under the dash about clutch pedal level i think its for the fuel cut off but im not sure
mikeymikeyp
Re: Stray plug!
Postby Mattious on Sat Dec 07, 2013 8:52 pm
Thanks dude I'll have a look around in the morning , been reading the Haynes but following thin black lines hasn't led me far!. :lol:
Mattious
Re: Stray plug!
Postby JasperJ on Sun Dec 08, 2013 8:46 am
That plug in the pic doesn't go to any thing, just leave it alone as 1 side is a permanent live :D
your problems sound more relay related to me, have you got the melted relay box syndrome?
:Q
JasperJ
Re: Stray plug!
Postby Mattious on Sun Dec 08, 2013 9:36 am
Ahh ! Ok cool , I had a look and couldn't find anything for it to attach to!.
Yes melted ignition relay , I cut and soldered new wires and sourced new relays but it's made sod all difference mate,
Mattious
Re: Stray plug!
Postby JasperJ on Sun Dec 08, 2013 12:48 pm
yea I had same trouble, my advice to you is to look for a cvh XR2i car loom as if you get another FRST 1 it will have been hacked for alarms and chances are the relay holder will be on its way out m8.
The burnt relay was a common issue with the frst due to the cooling fan running a lot when sat in traffic as it wasn't the easiest to keep cool with the bloody turbo sat behind the radiator,
I noticed a chap on ebay was breaking a turbo and a 2i so u may want to try him.
Ebay no 121231379672.
hope this helps.
:Q
JasperJ
Re: Stray plug!
Postby Mattious on Sun Dec 08, 2013 5:43 pm
Thanks for you all taking your time to reply, I've decided to source a new loom as to be honest this loom is no good to any one !
Thanks for the eBay link I've just mailed him :D
Mattious
Re: Stray plug!
Postby AW3K on Wed Dec 11, 2013 10:48 am
hi the red wired plug in the pic is the power feed to the heated front screen loom, it should live somewhere near the radio plugs taped up over the end as it s a perm live.
AW3K
