Strut Braces ?
12 posts • Page 1 of 1
Strut Braces ?
i was looking at them today and i noticed you can get upper and lower ones for the front and back. what is the best one to get ? cheers in advance
xr2 turbo
- joel_winders
my xr2i already has a lower strut brace fitted(i think), its held on my four bolts, try a srcappy and have a look, because the holes might already be there for it to fit on. i think other sporty fiestas might have them too.
- XRMike
I have Sparco front and rear strut braces (upper) and i believe they have made a huge difference in the handling of my car
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
joel_winders :so can i just get an upper front one and a rear one ?
Yes, you could just get a front one - you dont have to get a rear one....but it would stiffen things up.
http://www.fusionfabrication.fsnet.co.u ... tbrace.htm
- JamieFRST
- Keep It Tidy
i was going to order the rear one today from lee but you can't use your card it says on his site bank transfers or cheque. i'll have to write one when i get home now
xr2 turbo
- joel_winders
Max M4X WW :Thats an ARB!
No it's a brace that goes between the bottoms of the wishbones. The ARB is a peculiar set up on the Fez at it uses arms that attach to the shock body.
A front upper strut brace is a good mod to add and you will notice the additional torsional rigidity it provides
What's unusual about ARB's mounting to the shock??? As Mr Oranoco says, the XR2i S-shaped crossmember you talk about bolts underneath the car to prevent flex on the underside between the lower arm carriers. Expect to pay 10-20 quid for one of these, and up to 35-40 quid for the front ARB. You will need the correct shocks (with the ARB and brake line retainer mounts) to use an anti-roll bar.
