Strut braces
19 posts • Page 1 of 1
- White_Ford_Rich
Personal choice at the end of the day
- TomRS1800
Re: Strut braces
White_Ford_Rich :Are they really needed on a road car??
not really else they'd b fitted as standard.
as tom said, personal preference, and probably depends on where you are driving, i.e. country twisties or big open straights.
- adz
Or if your a big gay like Adamski its there for safety
- TomRS1800
ah, its not for me.
couple of mates have said about puttin them on thier cars.
personally i dont see a need for them, unless its on a track car.
one wants both upper and lower struts front and rear + a 40mm drop, it jus seems a little too OTT to me esecially as the car is a daily runner
JAP is CRAP
- White_Ford_Rich
Same as Max,i have a mk6 fiesta,which i am currently upgrading the suspension,wheels, tyres and brakes, and i will fit a front strut brace while im at it,as i like twisty roads i have also fitted some to my 2i. Im guessing their impact on the overall handling is minimal, but as known,every little helps
- XRMike
My rear strut brace was an impulse purchase from egay, but transformed the handling.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Unfortunately not. It's an alloy one that goes in between the turrets, about 35mm diameter tubing. If I was to buy another one I would definetly get one that bolts onto the top strut mounts, just for the ease of mounting. They are also properly designed for movement in both directions.
I got mine with some shocking self tapping screws and promply sheared two bolt heads off! However after a bit of redesign which involved welding in some strengthening plates inside the turrets and four alloy M12 nuts and bolts each side it looks the business and makes a real difference. Also deals with the movment of the turrets in both directions.
It has really tightened up the rear end, and on the two occasions I have accidentally got the arse end out (in the wet) it feels a lot more progressive rather than "snappy". Whenever I drive a fiesta without one I'm reminded what an absolute bargain it was.
- Ollybee
Hmm, I always thought they looked bodged. My OMP one should turn up tomorrow. Might not be as good then
Are you getting a top mount one?
- Ollybee
Yeah, that's the sort I would get now if I were to buy another. Just so much easier to put on, other than arsing around drilling holes in the turrets.
On holiday at the moment but I'll get some pictures of mine up next week.
You'll wonder how you ever managed without!
- Ollybee
Will be good if it makes a diff.
That's the reason i got it really. I have a habit of changing my mind so holes everywhere wouldn't be great!
TomRS1800 :Or if your a big gay like Adamski its there for safety
oh shut it U HOMO!!!!!!!!!!!
they are good if they are parcital braces not the (insert ghey rap term) (insert ghey rap term) flimsey ones!!!!
but the real question is - is any mod ever needed for a road car???
and as said only you can answer that, is it needed for what you use the car for???
- MAD_Adamski
Max M4X WW :Bolts to the 4 bolts that hold the shocks in.
Got one of them in mine,they are naff to put it blunt
I'll be going for some CDS tube and welding it inbetween the turrets so it actualy does something
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
