stuck nuts!! Help wanted
10 posts • Page 1 of 1
HELP
i need to get the rear shocks and springs off my car, to replace with uprated shocks and springs but i cannot for the life of me get the bloody nut/bolt moving tu take the bottom of the shock out of the swing arm. Been trying for thepast hour and a half or so but ran out of light!
its a mk3.5 '94 i need to get done asap so any help/suggestions would be extremely helpful
cheers in advance
cheers in advance
- woody23
Re: stuck nuts!! Help wanted
Leave it to soak in LOADS of WD40, then get a lever bar on a socket and it should come off easily
- - Danny Boy -
- Your car: Fiesta Si 2.0
buy an impact gun, cheap ones are not bad for this type of job, ive broken a few though
if you have the cash buy a decent impact gun, its worth its weight in narwhal horn, trust me
- Ruishy1
im on a tool buying ban at the mo!! the WD40 did very little. 15 years of dirt/rust proved too much for it been soaking for 2 days so i spoke to a chap at the local garage and he zapped them off in a jiffy for nowt! 'just goes to prove if you dont ask you dont get. so now sittin pretty on -40mm drop
cheers for your suggestions
- woody23
Good old bar and some muscle should get it done. Hammer on a socket if u have to. Can be a coont of a job.
- Hilton HS2
untC is rite almost put my shoulder out trying to free them been driving a hot rod all weekend!! thats why i went to see "the MAN" and his 10k ftlb impact wrench!! all done now looks better than std and no rolypoly corners!
- woody23
llama I did mine on my drive lying flat on my back with about 2mm between my gut and the car and nearly rocked the thing off the axle stands but they always give eventually, just have to remember that short sharp hard tries are better than a contant gut wrenching pull!
New Project In Progress!
- mintwhiters
- Your car: Moved onto Motorbikes
mintwhiters :llama I did mine on my drive lying flat on my back with about 2mm between my gut and the car and nearly rocked the thing off the axle stands but they always give eventually, just have to remember that short sharp hard tries are better than a contant gut wrenching pull!
i did pull mine off the stand thats y it went to the garage
no damage done tho thank god!
- woody23
mine was rusted on aswel so i just soaked it with WD40 and used a breaker bar came off with not much hassle
old fords never die...............they just get faster!!!!!
- white diamond
what i use to do in this situation, i got a spare bolt and got the angle grinder out lol
- Scott69
