Sub Box Size?
Sub Box Size?
Postby GeForce Junky on Mon Nov 13, 2006 11:48 am
Hi
I'm making a custom mdf box for this sub:
Image Image
Its a 12", 350W RMS, 1200W Max.
I'm going to use a single 4" round port. What approximate volume should I make the box?
Chris
GeForce Junky
Location: Gloucestershire Claims: To be FT's Sole Hillman Imp Launtic
Postby bassboy on Mon Nov 13, 2006 11:33 pm
howcome a round port?
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby GeForce Junky on Tue Nov 14, 2006 9:55 am
bassboy :howcome a round port?
bassboy
Er, because I already have one. What would you suggest, I'm a ICE noobie. I assume 12mm mdf is thick enough to build the box?
Chris
GeForce Junky
Postby diablosvy on Wed Nov 15, 2006 2:42 am
18mm MDF, and a slot port gives a smoother response, round ports are too peaky. But TBH with a Sony sub you wont really notice much difference anyway.
diablosvy
Postby mikeysabes on Wed Nov 15, 2006 10:32 am
They can drop better too, as well as sound better
all our boxes are slot ported or sealed now,
or can custom them, double skin etc
mikeysabes
Postby GeForce Junky on Wed Nov 15, 2006 11:22 am
Um ... decisions. Basically It going in my Hillman Imp, so the box sits on what is effectly the parcel shelf. The box will be cuboid, with the sub on the top, just about wide (front to back) enough for the sub and just about deep enough, then I was going to use width (side to side) to make up the volume. The parcel shelf in a Imp is effectly its boot, its narrow, about 4 inches deep and about 4 ft wide.
What sort of volume (as in widthxlengthxhight) should the box be? ... I am right in thinking the is a optimum volume?
Does anybody sell slot ports that can eaisly be screwed into a mdf box?
Chris
GeForce Junky
