sub connections
2 posts • Page 1 of 1
sub connections
im getting this sub - http://cgi.ebay.co.uk/FLI-TRAP-12-ACTIV ... dZViewItem
my headunit does not have preouts so im getting a line level converter - http://cgi.ebay.co.uk/FLI-Line-Level-Co ... dZViewItem
i want to keep the rear speakers but i need to connect the line converter to
them, can i still use the speakers? can i just tap off from the speaker cable?
or does this mean i cant use the rear speakers?
also are the items i have chosen ok? i have upgraded front speakers and
probably will for the rear after getting the subwoofer sorted out.
thanks
thanks
- matt188
easiest thing to do is to get a stereo with the outputs - you can tape off them so you can still have the rear speakers but it may lower the power of them - or you could run your sub off the amp and if it is a 4 channel amp, you can run the rear speakers from the amp.
- ~ John Reid ~
