"superchip" business
7 posts • Page 1 of 1
hey guys
how do i go about getting a "superchip" sorted out for my xr2i 8v? i have all the engine compotetion spec ready(i.e cams and port and polish etc..) and just need the chip but dont have a clue where to start and how they work etc.
any advice on this will be much appreciated
- slaney21
- Your car: Zafira A SRI 2.216V
Re: "superchip" business
They plug into the ecu. Get your ecu code, phone superchips, explain the other mods you have, pay them, get chip in post plug it in.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
the superchip or any other off the shelf chip is basically an optimised standard map.
They dont really make the most power out of all of the modifications as each car responds differently to each level of tune and how good the oigional engine is.
However they are very cost effective and good if you dont want the outlay of a custom map, which in all honesty wouldnt give much more than a superchip for that spec.
Best bet is to keep looking on ebay for a second hand one that matches your ecu code or ring superchips direct.
- xrsi
- XR(ustyAtTheMo)SI
ok cheers guys. 1 more thing..
how do i find the "code"?? sorry im useless and also whats the whole 195 and 165 chip all about?
- slaney21
165 and 195 only apply to a fiesta turbo so on an xr2ui that is not an issue (its basically stage 1 or 2 and meant to signifiy the power of the engine after chipping iirc)
the code off the ecu is got by undoing the 10mm bolt that holds the large rubber boot onto the ecu in the engine bay.
once the boot is undone the ecu plug can be removed from the ecu and a 4 letter code is on a printed lable on the front of the ecu at the top.
- xrsi
- XR(ustyAtTheMo)SI
i think the code for an 8v xr2i is 1AFA, if that helps
- hb69
- Your car: Fiesta 1.1 LX
ok guys cheers. i shall try and keep an eye out for a chip then
what sort of gain bhp will it give the car roughly? 7 - 8 or 12?? not sure
- slaney21
