superchip install
8 posts • Page 1 of 1
superchip install
hy,
can say their to me like one chip inserts
- fiesta turbo germany
What?
If its about pluging the superchip into the 0FAB/0FAC ecu for the first time:
- Unplug the negative wire from the battery.
- Take the ecu out of the car.
- Take out the cover of the diagnostic port.
- Unscrew all the bolts and take out the ecu's cover.
- Clean/degrease properly the diagnostic port contacts.
- Assemble everything back.
- Plug in the chip on the diagnostic port and tape it so it wont fall due to vibrations, etc
- Put the ecu back on the car.
- Plug the negative wire on the battery.
- Check if the engine starts
195 superchip and the 0FAB diagnostic port:
3 chips for the FRST
Hope this helps
Hope this helps
- BUTRE
Better terminals clean, you must.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
You will need to up the psi by making the stem of the actuator shorter just a few turn at one timefiesta turbo germany :one does not notice an achievement increase, if psi is not highly set?
- j7aoc
