suspension help > (fao Snake, Project, Excursion!)
11 posts • Page 1 of 1
right as most of you know i have a paltry 1400si which doesnt come with anti - roll bars
what i want to know is, if i get hold of a full pi or g-max ect kit for a 16v 1600 si will it fit? and will i be able to fit the 16v anti roll bars to this???
other thing is, i dont often see 16v si in the scrappy, will rst anti roll bars fit?
thanks for ya time mateys
- Mexi
rear you`ll have to sort out the mounting for the middle 2 mounts, as i don`t think the mounting points will be on the beam, the front u wont have the 10mm bolt holes in the lower arm units. On lou`s i`ve put xr2i lower arm mounts on so if she gets new shocks as some point the a-r-b will just slot on, although u could nut+bolt this into the lower arm cradle, dunno about the shocks, may run slightly diff a-r-b, lou`s can just have the 2i/frst one bolted on.
- snake
- Trainee Burger Flipper
- Your car: ford
ARB may go on but might interfere with Cat. 1600Si kit should bolt in place fine. ARB U-clamp 10mm bolt threads should be present in all lower arm carriers from 89-96 along with lower S-shaped (strut) brace crossmember thre aded bolt holes.
Geoff speaks the truth. Go, go forth and suspensify...
- Project
- fiftyoneCL
- chumkila
- Dirty Post Whore!
You need one of the mk3.5 front anti roll bars - they come in two thicknesses and both are designed for CAT's and PAS. Choose the 1600si/RS/XR one it's the thickest one that was fitted to a mk3 due to the extra weight of the car.
Rear - you will need a complete beam.
- chumkila
- Dirty Post Whore!
