Suspension - HELP
Postby icecool on Tue Nov 06, 2001 7:26 pm
Right, I currently own a 1995 mk3.5 1.1 Fiesta.
Just fitted 17's to it and need to alter the suspension setup to give it a drop of about 35mm.
What would I need to do this, I'm looking for a full kit to clear the tyres properly.
Also people have mentioned about spacers on the back but there is no way that they need pushing out any more, is this cos its a 3.5?
icecool
Postby MadcatCraig on Tue Nov 06, 2001 7:32 pm
yes it is [ERRR] its a 3.5 ! your gonna have major probs with 17"s im affraid as anyone here will tell you ! i think your best bet is to ask excursion who will tell you how he did it and then say its not worth it or get coilovers ! gonna cost you either way mind !
MadcatCraig
BANNED SELLER
Postby Mike on Wed Nov 07, 2001 3:46 am
I had mine lowered about 50mm and the only wheels that I could get to fit without modding the wheel arches where 14".
17" I am guessing will cause u problems.
Mike
Postby fiestastyle on Wed Nov 07, 2001 4:34 am
I have 16" on mine with a apx60mm drop. I needed no spacers either! Mine is a 94M 3.5 so that must be it!
tyres are 195.45.16
fiestastyle
Postby icecool on Thu Nov 08, 2001 7:38 pm
Yeah, must be different with the mk3.5.
Mines lowered 60mm on 17" wheels and rubs even though all the lips on the arches have been cut off as far as possible.
I want to raise it to a 30 or 35mm drop and really want to know what the best combination of spring and shocks be?
icecool
Postby zetec69 on Fri Nov 09, 2001 5:13 am
icecool mate-I used to run 7x17" wheels on my mk3.5 Si with standard shocks and -35mm chassis dynamics springs. I had to modify the arches quite a bit-(cut them back) but it didn't rub that much-normally only with 2+ people in the back.
Brad
LoW MoToR
zetec69
