suspension question
14 posts • Page 1 of 1
suspension question
was thinking bout lowering car 50mm. i have noticed the rear of the car is higher than the front, obviously cuz theres less weight in the back than the front. was wondering, if i were to lower the front by 50mm and the rear by 60mm would that make the car sit level??
cheers guys
cheers guys
- dee_RS_2ltr
trial and error mate,
maybe you should just bite the bullet if you want things that perfect and buy coilovers!
cheaper in the long run and the difference is well worth it!
I HAVE
I HAVE
- RS rob
The rear of the car is not higher "because there's less weight there". That could quite simply have been overcome by using softer or shorter springs at the back. The rear is kept higher for handling reasons!
hi my fiesta was 1300 and put an frst engie. ihave bilstein sport with apex springs. i think that my car could not be worst.help me what to do?
i have to change both of them?
my car does not have antiroll bar.does eibach have antirol ars for mk3?
sorry for my english i am from greece.
- makos13gr
Kalispera Makos! You can fit the XR2i or FRST anti-roll bar if you have the correct mounting points on the front dampers, and the threads in the lower wishbones to bolt the anti-roll bar mounts into The anti-roll bar (ARB) totally changes it!
mines lowered 40mm front and 60mm rear, and it sits pretty level. as heeman says though get the front arb, should make handling a lot better, i shall be putting one on mine when i get round to it.
- musicdrummer42
arb
Don't blame the antiroll bar (or the lack of it) for bad handling. Actually if you guys really would like to make your fast Fiestas handle, you'll have to make the the front end softer and the rear end stiffer. Better yet if the front antiroll bar is removed and replaced with "latter model"-like reaction bars with better bushes of course. This mod adds grip when accelerating and reduces steering torque.
I also recommend those adjustable lower arms, although they are heavily priced (after all it just two feets of Fe45 tube, few uniballs and bolts).
It's better to burn out than fade away
- Mizka
Re: arb
Mizka :
The fiesta mk3 handling is all wrong to start with.
The rear axle is really poo and a zetec-s one its a good VFM mod to start that twitchy rear.
At front, oh well cause alot needs to be done
Mizka :
They are way to expensive!!! I'm designing my own and the cost I estimate is 1/3.
The thing is that you need to think and draw some lines on paper to get them right. Not everyone knows how-to and whats needed to improve handling.
- BUTRE
Butre said:"-The fiesta mk3 handling is all wrong to start with."
I hope u didn't get me wrong, I ment that those setups (soft front/stiff back) will work if there are decent sets of aftermarket coilovers on, and yes it will make big difference with z-s rear beam.
One thing that should be consider when seeking for better handling is to get faster steering rack from old Fiesta Cup-cars. If they are too hard to find, then u gotta go for custom made rack.
OT:I got a rally-Fester project on the way (to Finnish national group F) where I need those lower arms. I would also make my own ones but those rally regulations don't allow "homemade products", and sertificate is needed to proof the durability. If u (Butre) manage to make proper drawings, is it possible to have a "look" @ those? I can always fake the sertificate...
- Mizka
Mizka :
I have a zetec-s ream axle waiting to be fit. Hope it sorts the rear instability, but I know its not going to be enough since I drive on track for low timing laps. I will consider on getting the anti-roll bar of the std frst rear axle... it needs to drill holes to get it on, but it will shure improve handling.
Mizka :
What steering rack from ole Fiesta Cup-cars??
Mizka :
I'm looking at it right now, but only going to manufacture a set for dumm fit next year or so. First need to sort the coilovers and corner weighting since seems that no one knows and does it here in Portugal
I guess that I'll be buying 4 scales but only after I order the coilovers
- BUTRE
Cup cars
Maybe you're not aware of the series which were driven with group A homologated xr2i's in mid nineteens in Britain (and in France I think). (I assumed that u were british ). Almost the same series is now driven with new Fiesta ST tuned in group n regulations.
Anyway those cup cars are full of competition goodies such as faster steering (rack & pinion), adjustable lower arms etc.
BTW how much you had to pay for the z-s rear beam? In Finland brakers ask about 250-270 € for normal mk4/5 rear axle...which I believe is the same as z-s axle.
- Mizka
