Suspension Top Mounts
6 posts • Page 1 of 1
Sorry if this has been covered 1000 times. When the car is jacked up how much movement/play is there on the front suspension top mounts
Cheers in advance
Cheers in advance
- kingabe
- Your car: Ford Fiesta RS Turbo
Re: Suspension Top Mounts
Too vague a question I'm afraid! If your finding it tough to turn the wheels you can lube them up but might just be easier to replace them, not much work and only cheap to do.
- Dazza
What I mean is when the car is jacked up, the top of the struts seem to move alot from above ie in the engine bay. Also when i turn the wheels the springs seem to be binding at the top when viewed from within the arch. They seem tight when the weight is on them. Is this just hence the name "floating strut!!?"
- kingabe
Still hard to diagnosis. I don't know your level of technical skills so forgive me if this sounds basic. When jacked up and you turn the wheel by hand, it will be stiff as the weight of the strut and suspension as it hangs will put pressure on the top mount however it shouldn't be 'that' stiff. The standard top mounts can perish so it may be worth dropping the strut to check the condition
- Dazza
They should be tight in the top rubbers, shouldn't have play.
- reithy
Cheers, Thanks for your advice guys
- kingabe
