suspension
11 posts • Page 1 of 1
suspension
I was just wondering if the suspension off, frst, rs18, 16v and 8v 2i's are all interchangable??
- durham fiesta
All inter-changeable up until the Mk3 Mk3.5 crossover point. Where there are differences to the front strut diameter. This is where the compatability between the Fiesta's stops
So this means i cannot fit XR2i 94>95 suspension to my 1.1mk3.5?
Should i just stick to 1.1 suspension from pi?
http://www.pi-suspension.co.uk/tsearch.php?search=+fiesta+suspension+94&Submit=Go
My theory is that an XR2i -30mm suspension will be lower than standard 35mm drop.
- richard_p88
xr2i's were standard height, the frst was lower
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
Oh well, i thought that all Si, XR, and RS models were slightly lower as standard.
Guess that makes choosing which set to go for easier then, I'll probably just go for the standard -35mm kit then.
- richard_p88
jdfiesta :xr2i's were standard height, the frst was lower
JJ
Wrong... XR2i's were 15mm lower than a standard fiesta
Formerly Jay246
- Jay
Car: 1992 Ford Fiesta RS 1800
Jay246 :jdfiesta :xr2i's were standard height, the frst was lower
JJ
Spot on
Oranoco :Jay246 :jdfiesta :xr2i's were standard height, the frst was lower
JJ
Spot on
you learn something everyday
JJ
- jdfiesta
- Your car: V70 T5
yes correct xr2i 15mm lower than standard si was standard height and frst was 25mm lower than all
frostie
frostie
- frostie
