t3 hybrid conversion
7 posts • Page 1 of 1
Hi m8s, what do i all have to change, if i put on a hybrid T3 on my 1.9 cvh fezzy turbo,
(cause a t2 (hybrid) is much too small for a 1900 cc engine i've heard !!!)
What to change on my magnex exhaust, inlet, oil-pipe, radiator/intercooler, does anyone has a 'manual' for this or does anyone sell conversions for it ???
Anything will help ???
cheers Thijs
cheers Thijs
- thijpo
hi
you will need:-
esc. turbo oil feed pipe-try hoses direct
esc. turbo exhaust manifod
t3 turbo
esc. turbo oil return pipe-about £10 from fords
esc. turbo downpipe
to fit it the radiator has to be moved forward about an inch
the esc. downpipe has to be welded to the fiesta flange
not a bad job to do but might take a bit of time
you will need:-
t3 turbo
esc. turbo downpipe
- nigel
You cant get the oil return pipe from Ford anymore its discontinued !!!!!!!
You can get all the others though and your looking at about 20-30 each for the other 3 turbo feed/return pipes
- EVO
