TD Van..ITS fudgekin DEAD AND BURRIED!!!! *19/10*
Postby TomRS1800 on Tue Dec 12, 2006 12:59 am
:Q Nice work son
TomRS1800
Postby cosmagedon on Wed Dec 13, 2006 10:33 pm
That wire going to the fuel pump, it will be for the stop solenoind if i remember correctly. And when i did my conversion on my escort, i also had another solenoid on the side of the pump, that was for the cold start and when it wasnt wired up the idle was terrible, and kept stalling.
cosmagedon
Postby Ghost on Wed Dec 13, 2006 11:17 pm
cosmagedon :That wire going to the fuel pump, it will be for the stop solenoind if i remember correctly. And when i did my conversion on my escort, i also had another solenoid on the side of the pump, that was for the cold start and when it wasnt wired up the idle was terrible, and kept stalling.
hmmm, ive done the middle one...cheers
but havent heard of the side one....?? any more info on which one it was?
Ghost
Postby Ghost on Thu Jan 25, 2007 1:28 pm
My fooking update for today is.....
The belt is timed and the car is home!!!!! :D :D :D :D :D :D
:lol: :lol:
Yes I have finally found someone to do the cambelt and time everything up! Towed the car back today, I'm going to get some power into it, fit everything back together and prime the turbo.
Then fingers crossed it will start :-?
Main thing im worried is the Fuel pump.....hopefully everything ive done to it means it will work :-?
SO! Work begins tomorrow morning :D :D
Ghost
Ghost
Postby Rhinopower on Thu Jan 25, 2007 1:30 pm
yes, lets hope the fuel pump has been sorted (they should of timed it up with a dial gauge when they did the belt) otherwise having all that off again will take you back to step 1
got a little list of what actually needs doing?
Rhinopower
Your car: Volvo FH330
Postby Ghost on Thu Jan 25, 2007 1:41 pm
well the fuel pump was dialed up as far as im aware....
I just mean changing over the Fuel shut off solenoid....as long as that is wirking and i dont have to do anything else for the pump to work :rolleyes:
To Do List.....
    Fit water pipes,
    Fill with water/antifreeze,
    Block extra pipe,
    Fit rocker cover,
    Prime turbo,
    See if fuel pump works and pulls fuel through the filter,
    Maybe change the complete filter system (as i dont think it works :rolleyes:),
    Get some fuel lines as a couple are stretched/broken,
    Fit exhust, cut and weld downpipe,
    Fit said downpipe............
soo not alot really before it gets up and running....IF everything works :lol:
Ghost
Postby rob pace on Thu Jan 25, 2007 1:49 pm
well done mate.
are you working on it all day today?
regards
rob pace
Postby Ghost on Thu Jan 25, 2007 1:52 pm
not going to go at it today...got some bits to do and it needs a charge as there is no power in it at all, and obviously i need some power to crank it :)
Ghost
Postby knuckles on Thu Jan 25, 2007 3:43 pm
nice one :D
glad to hear you got it sorted in the end ....
knuckles
Your car: Fiesta Rs turbo
Postby fiestadave58 on Thu Jan 25, 2007 7:04 pm
Brilliant! Good skills chief!
Hurry and and get it all done, we'll have to arrange a fiesta TD thrash some time! :lol:
fiestadave58
Postby Ghost on Fri Jan 26, 2007 3:11 pm
TD thrash :lol:
Right well, it cranks over but there is no fuel getting to the engine.
Im going to go out tonight and buy a new filter and hand pump that comes with it...if that doesnt bring the fuel up then expect questions in the Tech section :lol:
Ghost
Postby fiestadave58 on Fri Jan 26, 2007 3:28 pm
LOL
fiestadave58
Postby Ghost on Tue Jan 30, 2007 2:58 pm
Thought id put up a couple of pictures as the engine stands right now,
Arty :) :lol:
Now it does want to start, but i am just having a little trouble to get fuel up into the engine as its not getting past the hand primer....
Help is on its way....fingers crossed and we should hear it run this week....again hopefully :oops:
I have got a couple of new bits for the car, but they can all wait until the car is running......and i dont decide to sell up :cry:
Ghost
van
Postby slaney21 on Tue Jan 30, 2007 3:39 pm
hey ghost.
i must say the whole van look is really awesome. so much different and looks real effective!!! keep up the good work matey
cheeeerrs
lance :)
slaney21
Your car: Zafira A SRI 2.216V
Postby XRMike on Tue Jan 30, 2007 7:12 pm
Get someone to tow you and bump start it :)
XRMike
Postby Ghost on Tue Jan 30, 2007 7:59 pm
i cant if there is no fuel going to the injectors, it wont even pass the filter :cry:
Ghost
oh, and cheers slaney :)
Ghost
Postby ScottP on Tue Jan 30, 2007 8:54 pm
try the black box (some sort of security device in a amoured case my bro says) mate, my bros was on its way out with the old engine and a new one cured it with the TD in
Scott
6 positive comments in trusted traders topic :)
ScottP
Postby AW3K on Tue Jan 30, 2007 9:23 pm
ScottP :try the black box (some sort of security device in a amoured case my bro says) mate, my bros was on its way out with the old engine and a new one cured it with the TD in
Scott
as i was told the other day i thought d had it but it doesn't, as it dosn't have the led in the clock .
ghost, keep it up
AW3K
Postby Ghost on Fri Mar 16, 2007 8:57 pm
Right, thought I would revive this one from the dead.
After hassles with the car, working s**t loads and even more hassles with women. I have finally got myself in a position with loads of money and no woman to waste/spend it on.
This has given me new incentive to get the car on the road and drive the fooker again!
So, firstly I am going to buy a new solenoid and hand primer pump and then follow some advice thankfully given by Excursion and hopefully it will run...If not then I have a new pump ready to go on and we will see if that does the trick!
If it does then I will be able to crack on with the following,
    sort and fit exhaust and downpipe!
    then I can fit my new adjustable suspension
    my new lower arms with poly bushes
    finish refurbing my wheels
then it moves on the bodywork!
    Weld and spray the drivers door,
    spray the new bonnet,
    refinish my sideskirts to remove the holes where they were screwed on :rolleyes:
and depending on how far I get I will cut up and prep my front bumper for the intercooler and pipe that up, also get that sprayed!!!
only then will I be able to get the tax and insurance for it....
...all for the 13th May :rolleyes: :lol: :lol:
Wish me luck, and pic updates over the weekend! :D
Ghost
Postby XRMike on Fri Mar 16, 2007 8:59 pm
Cant wait :D
XRMike
Postby Ghost on Fri Mar 16, 2007 9:09 pm
Me either!
I want it there! :lol:
an I know for some very odd reason, that the van has a small following :lol:
Ghost
Postby knuckles on Fri Mar 16, 2007 10:25 pm
Ghost : and I know for some very odd reason, that the van has a small following :lol:
It certainly does fella :wink:
at this rate we will both have to get towed there, but i have faith :lol:
knuckles
Postby Ghost on Mon Mar 19, 2007 5:16 pm
Right, a little update on handling!
New avo's fitted ...
New lower arms fitted, powder coated white but I'll manage.....
Powerflex bushes....
getting there....if it starts, it will get there quicker :rolleyes:
Think I'm getting quicker at this sort of thing, changed lower arm and strut on the drivers side and removed and replaced the passenger strut in under and hour :aaah: :lol:
More updates to come in the next few days :)
That is all.
Ghost
Postby Rhinopower on Mon Mar 19, 2007 5:42 pm
hope the nut gun sorted you out ok :)
nicely done :)
Rhinopower
Postby Ghost on Mon Mar 19, 2007 6:02 pm
Rhinopower :hope the nut gun sorted you out ok :)
That thing is the bollox mate, I need to buy one! Any contacts?
Makes light work of everything on the car, apart from when the batt runs out when you are trying to use it! :lol:
Ghost
Postby Rhinopower on Mon Mar 19, 2007 6:10 pm
it undoes flywheel bolts, crank pully bolts, and diesel injectors without hesitation! Its made by standard power
Rhinopower
Postby knuckles on Mon Mar 19, 2007 9:58 pm
Avo's looking good fella- alot better than my ones :cry: :lol:
knuckles
Postby fiestadave58 on Tue Mar 20, 2007 12:21 am
Sweet!
P.S. Is your garden made out of astroturf??
fiestadave58
Postby Ghost on Tue Mar 20, 2007 12:35 am
fiestadave58 :Sweet!
OMG your still around :bonkers:
:lol: no, its got this eco-guard stuff on it. I think thats what its called. Its meant to be laid over earth, then filled like it is in the pictures. Then theoretically the grass grows through it and allows you to park on it with out it sinking.
But my car has been parked on it so long I think it has killed off any chance of the grass ever growing again.
Really need to get it off for the spring to give it a chance to seed up again :)
Ghost
Postby fiestadave58 on Tue Mar 20, 2007 10:30 am
Lol! I'm always around! :D
Sounds like a good idea in theory that stuff!
How much did you pay for your suspension as i could really do with getting some for mine?
fiestadave58
Postby Ghost on Tue Mar 20, 2007 12:18 pm
fiestadave58 :How much did you pay for your suspension as i could really do with getting some for mine?
bargain of £250 :wink:
Ghost
Postby fiestadave58 on Tue Mar 20, 2007 4:07 pm
Ebay?
fiestadave58
Postby Ghost on Tue Mar 20, 2007 4:34 pm
fiestadave58 :Ebay?
nah from the forums :Q
kept me eye open and me ear to the ground as these dont come up very often so I snapped them up :Q
Ghost
Postby Superal on Tue Mar 20, 2007 4:54 pm
Looking good...hope its done for fitp and let me know if you wanna sort out a quote at a bodyshop...mine going in soon for a nice machine polish :wink:
Superal
