temperature gauge
7 posts • Page 1 of 1
temperature gauge
hi, my temp gauge is not working, dosent even move off the bottom.
looking in the haynes manual it says to first check the temp gauge fuse, in the fuse section of the book it dosent mention temp gauge fuse in the list. Anyone know if there is one? and where?
car is a mk3.5 1.1 fiesta
- sam2k13
- Your car: for fiesta
Re: temperature gauge
try changing the sender on the engine... it will be under the thermostat housing on the left of the engine where the rad top hose is... wire may have come off/corroded or sender is knackard...
- AW0L
as above there only a few quid and as mentioned the wire comes off and corrodes
- stevo™
Thats great, thank for that, im prob gonna just go and change the 2 sensors (sender and fan switch) and the thermostat while im at it, because i don't think the fan comes on either, i know the fan works because i tested it. any idea how much this parts will cost at a ford dealer?
- sam2k13
sam2k13 :Thats great, thank for that, im prob gonna just go and change the 2 sensors (sender and fan switch) and the thermostat while im at it, because i don't think the fan comes on either, i know the fan works because i tested it. any idea how much this parts will cost at a ford dealer?
probably about £25-30 all in...
for the age of the car, just go to your local auto factors, will probably be around the same sort of cost for the 3 parts
Euro car parts
rad fan switch - 223590021
thermostat - 209590201
gauge sender - cant find online but must have them... if not i think i got a couple laying around
- AW0L
its the wee sender next to the exhaust many ,,take off the wire and earth it to the engine/body if the guage moves its the sender
If there isnt anything wrong with your thermostat dont change it
If it aint broke dont fix it you might break something
you never know mate you could snap a bolt in the thermostat housing
- mikeymikeyp
sorry my mistake didnt relise it wasnt a cvh just looked at my post to make sure i didnt sound like a knob
- mikeymikeyp
