The best CVH carb is?
13 posts • Page 1 of 1
at the mo ive got a twin choke weber which ive been told has been `re-jetted` .
i want to get a new one, completely strip it and rebuild it with the biggest fuel jets i can. what size jets should i put in it?
also, what carb [ERRR] i get?
one off a mk1 XR2? mk2 XR2? XR3? weber? twin choke?
can any1 suggest the way to go?
The PhatFiesta
May she live in our memories forever
- PhatMan
- It's a bit of an Animal..!
Demon Tweeks sell a 34/36DATR twin choke for a few pence shy of £300. Should sort you out nicely and goes straight on most CVH manifolds.
Tell 'em a big fat half-Welsh sheep shagger sent you
- Project
- fiftyoneCL
ok, weber twin choke it shall be.
£300 nicker sounds a bit much for [ERRR] i want at the mo.
Im aiming to get one off another motor, which ford has the best carb?
And how do i go about re-jetting it? to make it better?
The PhatFiesta
- PhatMan
Before you deicde against the £300 jobbie (although I'm with you on the price), compare the size of the chokes to the largets you'll find anywhere else - they're almost twice the diameter - more air allows more fuel allows more speed.
Innit
Innit
- Project
- fiftyoneCL
Boys, the best carb`s have to be the Weber twin 40`s for the cvh, u can pick them up for under £200, rebuild kits are £12 per carb and u can get a new linkage for under £50,Manifolds are £80-100 new, get it rolling roaded and you`re well away
Or you could go for the DCNF`s which are plentyful aswell..
- snake
- Trainee Burger Flipper
- Your car: ford
Rebuild them. The manifold and linkage etc, u can get everything from http://www.burtonpwer.com.
Linkage around £50+vat
Service kits £13.94+vat
Manifold £68.54+vat
You`ll need a sandwich plate set aswell and filter to fit, Burtons will sort u out..
Manifold £68.54+vat
- snake
- Your car: ford
wicked lads....
just bought my twin 40's today with no manifold for 80 nicker. one ventura is missing which im told will cost me bout £25, im gonna contact burton power now to see about rebuilding them and getting them banged on.
SWEET!!!!
SWEET!!!!
The PhatFiesta
- PhatMan
