The best way to install a Fiesta RS Turbo engine?
Postby Ice 159 on Sun Apr 28, 2013 8:56 am
Hi Guys,
My Fiesta RS Turbo engine is now nearing completion and ready for re-installation.
I was just wondering how would be the best way to go about this?!
Is it under and up of the Chassis or over and down?
I was just wondering what way people found the easiest....
Any help would be great and many thanks
Ice 159
Your car: 1990 Fiesta RS Turbo
Re: The best way to install a Fiesta RS Turbo engine?
Postby russ-RST on Sun Apr 28, 2013 9:09 am
I always fit and remove engines from the underneath as I find the brake servo and battery tray would get in the way massively . Wouldn't as much I suppose if you lifted in box and engine separate . But I always lift tr car up and stick the engine n box in from the underneath
Russ
russ-RST
Your car: fiesta rs turbo
Postby mikeymikeyp on Sun Apr 28, 2013 10:43 am
Me to i always built ad lift up it usually the best way
mikeymikeyp
Postby Ice 159 on Sun Apr 28, 2013 5:50 pm
That sounds cool.
Can I ask do you remove the Gearbox Crossmember and then bolt it to the Gearbox when it is out of the car?
Also what is the best way to slide the engine under the car and how do I get it in the air high enough to slide a whole engine under? I will add that I do have a crane available to me :)
Ice 159
Postby mikeymikeyp on Sun Apr 28, 2013 10:26 pm
Put it all togeteter engine box and cradle you dont have t tighten the 2 bolts on the rubber bushes ,Then get 2 jacks and a helper and lift the engine up on a jack and the box Dont put the jack on the cradle thats what youll be bolting up first , iv done a few myself and it is a bit tricky yourself but if youv got somebody with you its a doddle ,you just need to keep working it up on bricks
its easerir if u leave off the manys
mikeymikeyp
Postby Tweek on Sun Apr 28, 2013 10:28 pm
Engine and box bolted together, gearbox cradle attatched. Sometimes easier to remove the passenger side lower arm and carrier but I'd only do this if you either intend on replacing it or you're really struggling.
Use a thick ratchet strap on the crane, tie it around the front crossmember or a chassis leg and use the crane to lift the car up high enough for the engine to fit under, put large axle stands underneath to keep it high enough.
Slide engine under, lower car back down to original axle stand height.
Lift engine up into position and bolt in :)
Edit: MikeyP just beat me to it, ditto what he said :lol:
Your car: VW Golf GTD
Postby Ice 159 on Mon Apr 29, 2013 9:40 am
Hey Guys,
Thanks for all of the help !!
It's all clear now and we shall do this on the weekend....
Many thanks and wish me look :D
Ice 159
Postby mikeymikeyp on Mon Apr 29, 2013 11:41 am
Tweek :Engine and box bolted together, gearbox cradle attatched. Sometimes easier to remove the passenger side lower arm and carrier but I'd only do this if you either intend on replacing it or you're really struggling.
Im just a poor person and cant afford a crane lol it is a laugh doin it yerself like :(
mikeymikeyp
Postby Ice 159 on Mon May 06, 2013 9:54 pm
All sorted lads, thanks for the advice :D
I thought that I would include a few pics as a way to say thanks. :P
All running :Q
Ice 159
Postby Tweek on Mon May 06, 2013 11:58 pm
Win! :D
Postby Dave5300 on Wed May 08, 2013 12:21 am
Looks very tidy that! :)
Dave5300
Postby Gmc on Wed May 08, 2013 10:18 pm
i did it from above, but had to bend the tray up a bit, and bashed the servo to buggery. but still, it was my first engine swap lol
Scottish? :Join The West of Scotland RSOC
Website : http://www.westofscotlandrsoc.net
Gmc
Postby Ice 159 on Fri May 10, 2013 10:35 am
Cheers Guys !! :)
Not bad for an amateur eh?
Even cleaned the engine bay when the engine was removed as well.
Ice 159
Postby Dave5300 on Sat May 11, 2013 2:40 pm
This is how i did mine :D
Dave5300
Postby Ice 159 on Fri May 17, 2013 2:42 pm
Show off :wink:
Ice 159
Postby Dave5300 on Sat May 18, 2013 2:16 pm
:lol: :lol:
Dave5300
