Re: The Recaro Fiesta - restoration update 25/11
Postby jayrs on Thu Apr 04, 2013 5:08 pm
None as yet, just waiting for ambient temps to rise so I can get a decent temp in the workshop to paint mate.
Don't wanna push my luck painting when its chilly and dampness in the air.
Gotta say I'm a bit pissed off with the weather lol should be a bit warmer than it is, can't believe there's snow in April! LOL
Re: The Recaro Fiesta - restoration update 25/9
Postby Fraggle on Thu May 16, 2013 7:31 pm
Ford 1991 Diamond white - colour code was : B 0[/quote]
Proof is in the pudding ![/quote]
Need to check mine now :cry: :lol:[/quote]
Well Ive FINALLY( :lol: ) just checked mine, colour code ive got is B1...where it says "drive" ive a "2",
Yours says ford espania, Mine says "ford motor company" BUT all other numbers tie in with an rs, so im guessing mine is uk built and she deffo a pre 1991 build, so it may be a different code, apparently their are 14 shades, B1 is the year 1981 shade, the 1st diamond white.............. :-?
Oh and where is the UPDATES? :-? :Q :Q
Fraggle
Postby jayrs on Thu May 16, 2013 9:28 pm
Dude there ain't none, I'm disappointed to say I have to put the recap fiesta on the back burner due to the cold weather we had at the start of the year and now its warming up I got something else taking my time up, but there will be updates come
June as I would of finished, or at least be at a stage with the other thing where I can juggle the 2 together, as clarks car is mainly down to priming and painting, the day after I do some priming or painting I can work on the other thing for a day to allow extra drying time etc then go back to it, that's the plan anyway lol
I am disappointed though wanted to be back on the ages ago, I expected march to be warmer than it was, but wasn't gunna try painting in a coldish workshop just for the sake of getting ahead, as there would of been dampness in the air, so decided to wait it out
Postby Fraggle on Wed Aug 14, 2013 5:46 pm
Chop chop :D
Fraggle
Postby jayrs on Wed Aug 14, 2013 6:01 pm
Soon mate soon lol
I got
Pics of the work so far but will do a update soon...
Re: The Recaro Fiesta - restoration update 17/11/13
Postby jayrs on Sun Nov 17, 2013 10:55 pm
been a long while since i updated this thread, so here is an update.
havent spunt much time on this, this year, started back on it mid june, and done bits here and there.
as anyone whos painted before will know, a lot of time goes into prep work, so theres been more time spent on it that the current state of it shows, and theres been a few issues along the way with parts that i painted having to be redone as ive not been happy with them, and due to the paint really needing a oven to bake on, once painted i tend to leave it a week or more before doing other bits.
anyhow, here the update in pic form, the extractor seen at the end is one i made up as i didnt feel paying £22 a time to hire one was worth it, so knocked one up one evening :lol:
this is as it stands with the pics i have on my pc at mo, little bits are still being done now until end of month as temps in workshop even with the heaters on are only just about ok for painting, by end of month the heaters wont give me enough heat i dont feel
anyhow thats it for today, few more updates this monht to come as and when
Postby black2 on Sun Nov 17, 2013 11:55 pm
Looking good Jay.
Gareth
black2
Postby jayrs on Mon Nov 18, 2013 8:30 am
Cheers mate,
I got shed loads more pics, but just picked out a load of the ones which show a decent difference, as a lot of work done like prep ain't worth showing, but we're take. In the stages to send to clark
Postby Excursion on Mon Nov 18, 2013 12:28 pm
That's awesome, Jay. You're a very talented guy.
Postby Smo on Mon Nov 18, 2013 10:40 pm
That's looking pretty damn good! Well done :D
Smo
Postby jayrs on Mon Nov 18, 2013 11:31 pm
Cheers guys :)
Postby SLEEMAN on Tue Nov 19, 2013 12:05 am
brilliant work there jay for a make shift spray booth. gotta hate those fecking flies when they get in paint! but don't worry flat and polish will sort it.
and when you say the paint needs properly baking, what hardener and thinners are you using in the clear coat?? because you can source and infra red lamp or two, you can use 2k fast hardener and 2k fast thinners and the combo of these with the clear coat will get the paint dry over night. or even a drop of rocket hardener will do it just nicely!
SLEEMAN
Postby jayrs on Tue Nov 19, 2013 10:22 pm
Cheers mate, the fly wasn't an issue tbh, only the legs were stuck and it came off easy as pie.
No clear coat its solid white fella, using fast thinners and the hardner Clark got which I think is fast too.
Its touch dry within hours with the heat I got in there, but It is still soft for a couple days.
Small bits I've painted and out in front if the heaters have dried hard in next to no time so I think it could do with a oven really.
But I'm getting on ok with it, I will say, as I've said to Clark, I've not had paint that is like this before, all 2k solid I've used before dryed quicker and harder in a short time... And I mix this stuff as per data sheet 4:1:1 but as I say I'm getting in ok with it
Postby SLEEMAN on Wed Nov 20, 2013 12:40 am
fair enough last time I used solid 2k paint, had it under two infra reds and let it fully cure off for around a month. clear coat would dry faster than solid plus it won't fade lol! but try and see about any small infrared panels and leave it on one panel for around 20-30 minutes maybe longer. check to see if the data sheet on the paint you used has an infra red drying time
SLEEMAN
Postby jayrs on Wed Nov 20, 2013 12:53 am
I think when it come to my xr2 I'm gunna hunt down some cellulose :lol:
From what I remember it just gives temps etc on the sheet but I will double check it tomorrow, I do have them 4 halogen heaters which do get it fairly warm in there, there struggling to get a decent temp now, but its a big old workshop with high roof and its stone built, even in the hight of summer it feel like air con has been on, hence the plastic seen in pics to give it a lower ceiling, and separate one room from another to keep heat in.
It's not as bad as I've maybe come across, it drys ok and I have masked on new paint about a week later, but tbh it could do with time to harden off, even still I'm not gunna mop the crap out of it, not that it needs much IMO, I'll just lightly do it I think.
Small update at weekend will come, not much has been done to this this week, clarks over and odds and sods are being done to it, and some work to his mk2 as he has the use of me and my gear :lol:
Postby SLEEMAN on Wed Nov 20, 2013 10:12 pm
fair enough give it a whole month or so it should fully harden up and cure well. if you can from time to time give a bit of heat to see if it speeds it up a little.
SLEEMAN
Postby jayrs on Wed Nov 20, 2013 11:19 pm
Ah yeah it will have plenty of time to fully harden, I won't be mopping for a while and the main body has been painted for a couple
Months at least now.
As for heat, heaters are on every time I'm out there, as its cold in work shop as said above :lol:
Postby hamps on Tue Dec 03, 2013 10:47 pm
Fraggle :Ford 1991 Diamond white - colour code was : B 0
Oh and where is the UPDATES? :-? :Q :Q[/quote]
"B" denotes Diamond white, the number i.e "1" is the year, so B1 diamond white 1991 B2 1992 and so on :D
Demon Dipping UK
website coming soon. :)
hamps
Postby hamps on Tue Dec 03, 2013 10:48 pm
jayrs :Ah yeah it will have plenty of time to fully harden, I won't be mopping for a while and the main body has been painted for a couple
Paint looks awesome mate, nice nice job :Q
Demon Dipping UK
hamps
Postby jayrs on Wed Dec 04, 2013 12:01 am
Cheers dude, I'm impressed with it, I'm sure people that doing painting by trade would say otherwise though :lol: but yeah with the conditions and the fact I'm not a sprayer, it came out bloody well IMO
Postby hamps on Thu Dec 05, 2013 10:31 am
jayrs :Cheers dude, I'm impressed with it, I'm sure people that doing painting by trade would say otherwise though :lol: but yeah with the conditions and the fact I'm not a sprayer, it came out bloody well IMO
I have been painting cars for 15 years now and it is as they say "all in the prep" and your prep work looks spot on :D
I have used spray booths and make shift booths and even sprayed outside before now and you can get just as good a finish if you take your time, all a booth does is speed up the process i.e 30 minute bake etc.
Keep it up mate good job. :Q
Demon Dipping UK
hamps
Postby jayrs on Thu Dec 05, 2013 11:49 am
That's is true mate, a finished job is only as good as the prep you put in ( unless you can't paint for $hit lol) and I have to say I have over killed the prep work lol
Postby Fraggle on Mon Dec 09, 2013 10:48 am
Top job mate, i think you need too look at a career change.............
now tell me c i want a mk5 scuttle panel!!
Fraggle
Postby jayrs on Mon Dec 09, 2013 11:08 am
Lol not enough money in it tbh mate not here anyway
Get a mk5 one fella, after fitting this one I'm thinking I should of gone that way but never mind lol
Postby Fraggle on Tue Dec 10, 2013 1:40 pm
And its deffo a mk5 scuttle?...
im just really not prepared to pay 100plus squid for a cut off mk3 one so if a mk5
fits i go find one.......
Fraggle
Postby jayrs on Tue Dec 10, 2013 2:54 pm
Yeah deffo a mk5 one mate
Postby HCS PIMP on Wed Dec 11, 2013 9:18 pm
Did jay fix the workshop roof then looks loads better nice work
HCS PIMP
Postby freddie4 on Fri Dec 13, 2013 4:59 pm
Fraggle :Top job mate, i think you need too look at a career change.............
He doesn't have a career! He's been on the dole for years!! :bonkers: :rolleyes:
freddie4
Postby Rs Adz on Sat Dec 14, 2013 8:22 pm
stunning work
Rs Adz
Your car: xr2i and mk1 fiesta
Postby jayrs on Sun Dec 15, 2013 12:23 am
Cheers dude
Postby Fraggle on Sat Oct 18, 2014 7:18 pm
You boys finished her yet?
Fraggle
Postby jayrs on Sat Oct 18, 2014 9:08 pm
I'm ashamed to say no :0( nearly, but I started a new job in the spring and just haven't had hardly any time to do anything.
More has been done just not updated thread
Postby Fraggle on Sat Oct 18, 2014 9:57 pm
Congrats on the new job bud,, not paint spraying is it :wink:
Guessing Mr C is still fiddling with that grey whale then..tut tut he needs too
Finish his proper white lightning first :P
Fraggle
Postby jayrs on Sat Oct 18, 2014 10:00 pm
Lol na back into refigeration, back on stand, by one in two.
I did take a week off to get some done but had a bit of a set back on the binnet and that wrote off 2/3rd of that week so yeah didn't get much done that week, but its all good, it will get done
Postby Fraggle on Sat Oct 18, 2014 10:05 pm
jayrs :Lol na back into refigeration, back on stand, by one in two.
Works work, moneys money mate so feck it its all good, no slacking off staffing duties though :lol:
Tell him hurry fxuk up this forums too quiet, we gotta keep going on these and keep
The breed an forum going!!
Fraggle
