The ST170 Track prepped Mk1, VVT Controller 08/05/14
141 posts • Page 2 of 5 • 1, 2, 3, 4, 5
Re: The ST170 Track prepped Mk1, Update, 09-07-08 More progress.
Excellent work, Steve, You've always been an inspiration.
Are you around on Sunday 20th? I'm taking the girlfriend away for a weekend, and it would be good to stop by your place on the way back, maybe you can get Lib involved and we could all go for some food?
Excursion :Excellent work, Steve, You've always been an inspiration.
That's one of the most normal things I've ever heard you say
Steve, fantastic work! Did you machine that pulley yourself?
- Sphinx
Sphinx :Excursion :Excellent work, Steve, You've always been an inspiration.
It sounds normal at first, but if you look deeper he is clearly implying a midnight glory hole session in deepest Somerset. . In time you will learn that with Mark, it is always about either glory holes or dogging in carparks.
Steve, you work astonds me!
- ~nomad~
- Your car: Breadvan
Excellent work, going to be a great track toy
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
lovin the cage and the fule system set-up
rapid progress on this one
can't wait to see the paint
- rsonblackwheels
Re: The ST170 Track prepped Mk1, Update, 10-07-08 Shell Painted
Thanks for the positive comments.
Mark, would love to mate. I know just the place, they serve meat in various states of cook, and mucho other good feasts. They also serve some rather fine Ciders! Give us a call some time.
Sphinx, My brother is handy with many engineering tools too, (must be in the genes) he made the pulley. I think Mark may be high on something, because I have to agree, he sounds almost normal!
Nomad, Thanks man! Hopefully we can all be on the track together at some point this year, or next maybe.
Fezzy Turbo, Thanks mate, I think it should be a fairly capable little car.
rsonblackwheels, Thanks for your comments. It's your lucky day, the cars painted!
I have had a fairly busy day today, I've been getting the paint finally sorted.
I stone chipped the inner wheel arches, and the floor of the car.
I then primed the whole lot again:
Then on went the matt black. I wasn't sure about it to start with, but it actually looks pretty cool!
So she can go back on her wheels tomorrow, and some interesting bits to do, whoop!
Steve
Steve
- Captain Tightpants
hmm not sure on matt paint, never really looks pro done imo!
rest is awesome though, loving that cage and engine
6 Point Safety Devices Cage.
- purple_fiesta
You can neeearly see the rear diff carrier in that back pic
wow looks soo different from when i was there
i like the matt black look
- GavStyli
- Your car: Fiesta Turbo
loving the colour
- ~nomad~
The colour looks so good
- hb69
- Your car: Fiesta 1.1 LX
looks great
one thing I have always wondered though is how you care for paint when it's matt? I assume you don't polish it, but what would you do to protect the paint?
- Chris 2i
The main reason it's matt is because he's not bothered about polishing or waxing it, it's there to be used. If the paint goes crap for any reason, we just repaint it! In Fairness, 5 litres of matt black is £25. Thats less than some polishes!!
Steve
Steve
fair enough, I'm quite tempted to paint my daily drive matt black...
- Chris 2i
me too makes so much sense, respray for £25 result!
- GavStyli
Re: The ST170 Track prepped Mk1, Update, 11-07-08 Loads done!!
Thanks for everyones comments again!
I'm doing pretty well so far, we're on day seven of the build!
Now all the crap work is done, the interesting stuff can happen, and it has been!
Firstly this morning, I went about modifying the clutch to be hydraulic rather than cable. I'm using a wilwood master cylinder. I started by making a small pivot out of mild steel, with a thread for the master cylinder, I also strengthened up the pedal and made the 'output' on the opposite side:
I then went about making the master cylinder fit the actual pedal box:
An action shot from welding the pedal box:
And then a great photograph of the box finished:
Fitted to the car:
I also finished modifying the bias pedal box and fitted that at the same time:
I then moved on to fitting the front suspension, including the Leda's. You can see the brackets I had machined up to locate the 4-pot wilwood calipers:
A view fitted:
The view from behind with the wheels on:
Jim proved his worth earlier by helping spike fit the new rear perspex windows:
James from next door, JEK, strengthened up the gearbox mount for me too, from where I had modded it:
I managed to start getting things like the loom back in, and the headlights in:
The head was returned today too, I'm real pleased with it. He's done a fantastic job of opening out and matching the ports:
It's genuinely hard to tell the change over from head to manifold!!
Pictures speak a thousand words and all that, so there you are.
The engine will be built back up tomorrow and get it back in all being well.
Caaapitan, Tighty Pant
Fitted to the car:
A view fitted:
wsome good fabrication and some good ideas, will be a little animal when finished, credit to you mate is a perfect advertising tool
- garyhurn77
I will pray to the powers that be that with the head and cams in their current spec, we can creep past 195bhp at the flywheel. Fingers crossed we can break 200! See you in the morning
Wow, awesome car - rat look
- Brammer
- Your car: Sierra Cosworth
Brammer :Wow, awesome car - rat look
Hardly Chris! How very offensive!!
Re: The ST170 Track prepped Mk1, Update, 12-07-08 Engine & TB's
Still can't get over the speed this is coming together
is it just a standard ST170 engine? & what throttle body set up are you using???
can't wait to see when its done
TOP WORK
TOP WORK
- Swiss
Gonna be awesome mate
Brian
Brian
- Bkjames
TOP TOP work,should be amazing when its done.keep up the awesome work lads
- PMK3
Re: The ST170 Track prepped Mk1, Update, 19-07-08 ECU & Brakes
Swiss, I like to keep things moving fairly quickly! The engine spec is fairly standard all bar, ported and polished head, no cat, all pumps removed, twin Jenvey 48mm TB's, 440cc fuel injectors, emerald K3, custom exhaust system.
Hard to remember what I update and what I don't!
Anyways!
The arches have now been painted and fitted:
I've also installed the whole braking system now.
Including a custom handbrake cable and brakets for the rear wilwoods:
The custom clutch pedal is now linked to the slave cylinder in the box via some goodrich goodness:
I have also now made and fitted all the brake lines:
I have also made the vehicle loom, and installed the Emerald K3 ECU:
A quick one of the TB's now ready to rock & roll:
Waiting on a few bits now, the exhaust is completed and the rad is all but completed.
Hopefully running and mapping on Wednesday,
Capn
Anyways!
Capn
What driveshafts have you used Steve?
- Sphinx
awesome progress
should be a little beauty when finished! are the wheels 16" or 17"???
- garyhurn77
steve have you got a part number for the connector on the clutch line to the clutch relises bearing as i cant find one in any of the cat's.....
- xrsi
- XR(ustyAtTheMo)SI
Sphinx, I will be making those tomorrow.
Gary, 15" Wheels.
XRSi, Sorry mate, can't help you I made that one.
Steve
Gary, 15" Wheels.
Steve
Automotive pawn
Are you just closing at the end of the month? how long have you got to clear out of the unit? You planning to get it all finished by Ford Fair?
Any news on my car? can you give me a call when you get 5
- JamieFRST
- Keep It Tidy
- Turboboy67
- Your car: 911GT3 RS
Captain Tightpants :Sphinx, I will be making those tomorrow.
Gary, 15" Wheels.
Steve
dont fancy knocking another up do you for bit of beer money!
- xrsi
- XR(ustyAtTheMo)SI
So when it's done, I'll come and collect it yeah?
- Sphinx
looks awesome,gonna be a beast!
- simon-turbo
