things i need to change?
6 posts • Page 1 of 1
been looking for a guide or info on converting my 1300 hcs festa to a cvh or zetec powered motor
just wondering what i'll need seen asthough i only have the 1300hcs
different fuel lines pump? cvh/zetec
engine mounts? cvh/zetec
any info greatly apreicated
regards
lee
regards
lee
- leeboi
Re: things i need to change?
Firstly you need to decide on your budget and what engine you would prefer, Turbo or N/A?
But as a rough guide you will need to change the
mounts
fuel lines
fuel pump (and probably tank)
engine loom
ecu
exhaust
Then you would also need to think about upgrading the brakes/suspension if you are going to make more power. There is a lot of work needed but if you/your mates can do most of the work yourself you could probably do it reasonably cheap.
Were you thinking turbo or N/A??
mounts
fuel lines
engine loom
ecu
exhaust
Devil-developments
2.1 Zetec Turbo/GT3076r/KMS Management -
Fast Ford @ Brunters September 2008 - 0-60 6.03s - More to come...
Fast Ford feature June 2009
- Matt_fez
tbh i was just thinking n/a
and i was hoping i wouldnt have to change the tank
i was just looking for the easiest , cheapest engine conversion tbh
didnt realy matter that much to the power figures aslong as i was stuck with the piddly hcs
- leeboi
reet, i wanna zetec it
apart from engine loom ecu and mounts, what else am i gune need/change?
- leeboi
If its just going to be N/A you could proberly get away with XR2i and Rs1800 Fuel pump, Fuel lines, Fuel Tank, Fuel filter etc
Bigger Brakes, Xr2i or RS1800 Suspension, think you can use Si engine mounts, gearbox.
You will also need to modify the engine so it all fits and runs. e.g Throttle body, water pump etc..
Hope that helps
Hope that helps
- joeRs
