throttle bodies and managment
8 posts • Page 1 of 1
Will i be able to get a plug and play performance package containing throttle bodies and aftermarket managment with map already on the ecu for a 2.0 litre zetec for under £2000?
- paradox
Such a conversion for that price at the most would probably be possible with PVE in Somerset, run by "Scort" on this forum. He's a busy man, and I realise it's a long way from you, but he's done a similar setup in a Saxo with a great deal of success. Megasquirt management, throttle bodies and a decent exhaust system saw good power and success at a local hillclimb, including a class record! Drop him a PM anyway
Thx for the reply heeman.
The reason im asking is because my engine bay looks like this atm
Its empty i have a gearbox put to one side and thats more or less it.
I would like an engine with a fair amount of torque great reliability and about 170bhp with scope for more at a later date.
And at the absolute maximum i want to spend from start to finish £2-£2.5 thousand.
Ive looked at loads of options and started buying a fair few bits to go zetec but if im completly honest i now have no idea what to do so all options and suggestions in my price range will be read and taken onboard greatfully
- paradox
Alright mate.
Jenvy throttle bodies on a 2.0 zetec seem to be the 'in' thing with kit car owners,as many have come into work with bacisly the same setup,and i guess most are reaching 200BHP also with a few extra mods.
Try http://www.trustelectrical.co.uk/ for some prices on some setups
- XRMike
retro ford do a kit for £1430 using emerald ecu. its aimed at mk1 escorts but its for a zetec 2.0 and thats what counts. its less than 1/2 that for a setup using megasquirt and gsxr t/b 's. if you want to play more... mike.
- alladdin
Read http://www.fiestaturbo.com/forums/viewtopic.php?t=103676&highlight=megasquirt+throttle+bodies
Will tell you all you need to know.
- Badgerboy
a company called burton power provide a webber tb kit with a map preprogrammed it runs the omex3 ecu ithink ill dig out a link
as the website is a flash i cant put a link but il give instructions
go to burtonpower.co.uk
go onto fuelling
go all the way to the bottom of the list
it should say throttle body injection
this is probably the best system youll get for 2 grand as its already set up and comes with all the sensors and evrything
go onto fuelling
- edders
